Question about Tag Heuer 2000 Aquaracer Chronograph CAF1111 Watch
Tag heuer careera automatic watch stops after five minutes
5 Related Answers
Anonymous
  • 203 Answers
SOURCE: Change the date on my TAG Watch
if it has hands the winder will be screwed in undo this anti clockwise then click it out once for date twice for time, if this helps please rate me joe
Posted on Nov 22, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
Posted on Dec 31, 2008
Anonymous
SOURCE: Tag Heuer CA 1211-RO Min. Hand resets to 59 Min.
Unscrew the crown and pull out halfway. Use the stopwatch buttons to advance the hand to where you want it. Then push the crown back in and screw it down. You may need to pull the crown out all the way--I cannot recall which setting controls the minute hand and which the hour hand on the stopwatch function. This has to be done every time the battery is changed.
Posted on Feb 05, 2009
Anonymous
SOURCE: tag automatic watch = stopped working
Stop shaking it!
You could try wearing it and it should wind itself with your body motion or...
your could manually wind it (setting 1)
Posted on Apr 17, 2009
Bob Gemmell
Bobby G
  • 212 Answers
SOURCE: Tag Heuer watch runs fine; can't set time or date.
Are you aware that the crown is threaded and it needs to be unscrewed and pulled out once to adjust time and twice to adjust date
Posted on Aug 07, 2009
My tag heur automatic watch has stopped working completely
If it's a genuine Tag Heuer, then you have a high quality watch that is worth the cost of repair and you should take it to an approved Tag Heuer dealer to have it repaired.
On the other hand, if it's a cheap replica, throw it away........
Oct 19, 2017 | Watches
How to synchronize Tag Heuer CAN1011.BA0821?
Unscrew the crown, start the stop watch on the time signal. Stop the second hand at 12 o'clock and reset the time (taking out the back lash on the minute hand) Start the watch as the stop watch second hand hits 12. Screw down the crown. Done.
Aug 05, 2014 | Tag Heuer Aquaracer Watches
Hi, I've got a automatic tag aquaracer watch that loses about 4 mins every month (about 4 yrs old). Common problem? Can this be fixed ? Or is it a lemon of a watch? Any advice welcome. Cheers.
If it's automatic and 4 years old, it's probably time for a watch overhaul. Auotmatic watches need overhauled about once every 4-5 years. It's normal for it to lose time, but 4 minutes per month may be a little extreme. So, get the watch overhauled. I would recommend Tag Heuer to overhaul it.
Sep 09, 2011 | Tag Heuer WAF2110.BA0806 Aquaracer...
I have a Tag Heuer Grand Carrera. It worked perfectly for a year. But now, it doesnt work. When I shake the watch, it starts and then stops again after few minutes. I was told to wind it. But I dont know...
If your watch is "automatic" then would I be right in thinking you took it off for a few days and it stopped?
If this is the case (since most of the Carrera range are automatic, then the spring will have run down and needs re-winding.
You were correct in thinking that shaking it will re- start it but to keep it going you need to shake it gently from side to side for some time. (One supplier quoted 500 times!) be patient and keep wearing it.
Oct 14, 2010 | Tag Heuer Carrera Auto CV2113.FC6180 Wrist...
My tag heuer link automatic stopped working what could be wrong with it
Assuming the watch wont start when worn then its time to get a specialist watchmaker to investigate.A premier watch as you have will need regular servicing at 3-5 year intervals.try www.rolexrepairs.co.uk they will provide a free estimate and operate a fully insured postal service.
Aug 16, 2010 | Tag Heuer Link Automatic Chronometer...
I have a Tag Heuer Monaco watch. I has 2
The small seconds hand do not stop because it has nothing to do with chronometer. It is ordinary seconds counter and will move independent of chronometer.Click on my profile (escapement), then click on Tips and Tricks. There you will find link to Tag Heuer watch manuals. It might lelp you. Rate me, please
Mar 31, 2010 | Tag Heuer Link Automatic Chronometer...
Tag automatic watch = stopped working
Stop shaking it!
Jan 22, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Tag Heuer Button Popping Out
If that buttun is pushbutton, then the fixing stopwasher has come off (inside watch).
If you meen the crown (winding and setting button), then setting lever or setting lever spring is damaged or broke.
Find your nearest watchmaker as both need professional repair and parts.
Dec 22, 2008 | Tag Heuer Link Automatic Chronometer...
Tag heuer link automatic
exact same problem, no one seems to know
Oct 26, 2008 | Tag Heuer Link Automatic Chronometer...
Tag heuer carrera automatic wv211a
Your watch is a automatic. All automatics need to wind-up before being worn at first , or if not worn all the time. Automatics will work with-out being wound ,but will not keep time. Wind your watch at least 50 turns (using the crown) or shake about 150 times , and then try it . Automatics need that back-up power to insure it's accuracy.
Jun 19, 2008 | Tag Heuer cj1110.ba0576 Wristwatch
Tag Heuer 2000 Aquaracer Chronograph CAF1111 Watch Logo
Top Tag Heuer Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
