Question about Homedics Home Touch Ps-200 Perfect Steam Commercial Garment Steamer
I need a hose replacement to my PS200. The gray plastic connection piece from the base of unit that goes into the hose broke and it broke off inside the hose! Does anyone know how to find one? The site posted here at the top for Jan 2009 is no longer good.
Posted by Sandy VanValkenburg on
  • Sandy VanValkenburg Nov 29, 2013
    Thank you Ernesto Cuadra! However, I clicked the link and I have never been to PennySaver before (ty for the link!) and am wondering if l need to go into each state and look for my item or if u know where it is? I wanted to make sure before l spent all that time going to each state that had Homedics items. I did search 'steamer' but it came up 0 so then l thought well maybe they didnt have any?
ernesto cuadra
    Top Expert:
  • 12,223 Answers
Posted on Nov 29, 2013
Testimonial: "Thank you Ernesto Cuadra! However, I clicked the link and I have never been to PennySaver before (ty for the link!) and am wondering if l need to go into each state and look for my item or if u know where it is? I wanted to make sure before l spent all that time going to each state that had Homedics items. I did search 'steamer' but it came up 0 so then l thought well maybe they didnt have any?"
Shark Super Steamer
The steam generator is defective.
Aug 28, 2016 | Euro-Pro Shark Super Steamer
Where can I get a replacement plastic part?
Try the place that you bought it. They may have the supplier / manufacturer information of where you can get parts from.
Sep 19, 2015 | Yamata PSS-2001 Power Stand-Up Steamer for...
When has my iron stopped steaming and heating up?
depends on how old it is, try to rinse it with a water and vinegar solution, this might help
Apr 09, 2015 | Euro Cuisine Ootoo Iron, 1500 Watt Steam...
Elna ironing press manual
I don't have a manual but these are extremely simple to use once and there is a demo on youtube for business shirts How to use Elna Press for Ironing Shirt and other videos from same member show sheets and jeans. Technique is simple, place part of garment onto the board with the rest sitting on your knees (use press sitting down in front of it) to take the weight, lower press closed with your left hand, then bring the spring loaded right handle down to apply the pressure, this has a big spring behind it and applies pressure, wait 2-3 seconds then lift right handle to release the pressure and then using your left hand grip the whole press will want to open up again. That's it! Set the temperature setting on the press and iron from your lowest temperature items first, nylons, up to cottons, linens on the hottest setting last as it will take 5 minutes or so to come up to full temperature. If you have the vapojet spray attachement, then you fill this with tap water and slide it onto the handle, give it a spray with the press open before you close to press and it turns to steam. Cleaning the top hot plate can be done with a special cleaning stick product you can buy (or any similar iron cleaning stick will work too, but you need to apply it to a hot plate so be really careful as you do this, then wipe it off with some waste fabric. Great press to own and perfect for applying interfacing if you are a sewist, (just use a piece of waste fabric so side of the interfacing doesn't attach to the top plate or your bottom cover).
Jul 12, 2014 | Garment Steamers & Presses
Home touch steamer
hose kinked or generator bad.
Dec 18, 2013 | Garment Steamers & Presses
Doesn't steam
the hoses sometime kink when hot then get hard in the kink part once cooled down.. you may need to fin the area and warm it up to let the steam pass..
Dec 13, 2013 | Haan Complete Multipurpose Steamer MS-30R
My boiler keeps making a ringing sound. Like a small bell on a bike. What could be causing this noise
Note sure if its the same thing but my boiler (halstead Best 50) made a ringing sound just like you describe. It was the flue fan blades just catching the metal surround of the flue vent on occasions. It only happened when the boiler had been running a while. A new fan was fitted and everything ok now.
Oct 28, 2013 | EuroSteam Steam Iron w/Boiler Tank & Lint...
Homedics Home Touch Ps-200 Perfect Steam Commercial Garment Steamer Logo
373 people viewed this question
Top Homedics Garment Steamers & Presses Experts
Tom Chichester
Bill Boyd
ray gallant
Are you a Homedics Garment Steamer and Press Expert? Answer questions, earn points and help others
