Computers & Internet Logo
Question about Cnet Computers & Internet
No power as i switch to 12volts adaptor
Posted by neil dejesus on
I have a 1997 chevy lumina with 3.1 engine. im not getting 12volts on connestor a on the left side of icm i checked all fuses they look good.could it be the ecm or the ignition switch thanks.
im not getting 12volts on connestor a on the left side of icm i ????? ICM - ignition control module ? Has only one power wire - Pink connector 2 - terminal B , Gets B+ voltage from fuse ELEK /IGN 15 amp fuse located in the under hood electrical center #1
How do I replace radiator fan
Did you check the fuse? also check coolant switch(it controls the fan). Are you sure the fan is bad?, try connecting 12volts to fan connector,if it runs problem is elsewhere, with key on, check for 12volts at coolant switch( neg lead to frame,red lead to one of the contacts on switch), if no power, check fuse, if i remember right there are 2 fuse boxes, check owners manual for location.
Does not turn on.
It is a power problem and the troubleshooting should start from the electrical socket where the adaptor is plugged.Plug an equipment in the same socket to confirm if power is present.If there's power,the 12volts AC adaptor may be faulty.
Blower motor won't turn on
Check again the wiring, why was there a cut in the wire first time, Had it rubed on a sharp edge? Has it happend again? Have you got 12Volts at the fuse and relay when switched on? Have you got 12Volts at the motor connection if not you have another break in the wiring power or earth or switch is broken or motor is possibly burned out. Hope this helps.
1helpful
I'm installing a pioneer deh- 2750mp cd player into a '92 Ford Laser, and was wondering how the wire colours match up?
Hello! Ford wiring
Power
Constant +12volts Green/Yellow
Switched +12volts Yellow/Black
Ground Red
Power antenna Blue
Illumination Blue/Red
Speakers
Front Right + White/Green
Front Right - Green/Orange
Front Left + Orange/Green
Front Left - Light Blue
Rear Right + Pink/Blue
Rear Right - Green/Orange
Rear Left + Pink/Green
Rear Left - Pink/Blue
Guru..............saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
I just installed the unit, It gets station info, but no sound?
Hello! Check the vehicle's wiring to the new unit...
Ford wiring
Constant +12volts Green/Yellow.............+12volts with key off
Switched +12volts Yellow /black...............Ignition Sw.
Ground Red...............unusual but true
Illumination Blue/Red.................Radio lights
Send a comment.....I am here!...........saailer
My car wont even turn i have tryed trobleshooting the safety devices and they are working properly. i have a new battery and a new starter
go directly to the starter and see if you have power ( 12volts) at the main cable and 12volts at the trigger wire with the key turned to the start position. If you have both, likely the starter has failed. If no power at the trigger, you may need to look at large underhood fuses and check ignition and neutral safety switches as well.
I recently bought a 2002 Pontiac Sunfire SE for my grand daughter as a High School graduation gift. Now the power windows won't go up or down. What could cause this problem? Hoping it is something simple...
This is One with the Power Window SWITCH in the CENTER Console they Often Get Liquids SPILLED on them Causing them to Fail, I Would First Check for 12volts @ the Switch with KEY ON. With a Sure 12volts Going IN the Switch Check for 12 Volt going OUT, If Switch IS BAD there Will be NO 12volts Coming OUT With this Go on to Switch Replacement
REMOVAL PROCEDURE
  1. Use a flat-bladed tool in order to remove the power window switch bezel (1) from the console.
  2. Remove the electrical connection from the power window switch (2).
  3. With a flat-bladed tool release the power window switch (2) tabs, and remove the switch from the power window bezel (1) retainers.
INSTALLATION PROCEDURE \
  1. Install the power window switch (2) into the power window switch bezel (1) until fully seated.
  2. Connect the electrical connector to the power window switch (2).
  3. Install the power window switch bezel (1) to the floor console.
((((>>>All of this is Assuming that All FUSES Related to And RELAYS Related to Windows Have Been Deemed GOOD & Funktional<<<<)))
If Further HELP / SUPPORT / INSTRUCTIONS Are needed P L E A S E Dont RULE me Out as I have the Answers, Just Try to be as Spisific as Possible and I will be More than HAPPY to Help you With your Needs of Auto Repair
1helpful
Starter problems
you need to check and see if you have 12volts at the relay and if you have 12volts at the wire from the switch on the relay. if you are getting power to the wire from the switch then you may have a bad starter relay.
I have a 94 buick century the power windowa do no work i replaced the motor and fuse
You should have 12volts on the orange wire to the switch and a good ground on the black wire. If you have power and ground at the wires you can check the switch. The blue wire will get 12volts when pressing the switch in the up position. The brown wire will get 12volts in the down position. A common problem is the wires break where the door opens and closes.
Top Cnet Computers & Internet Experts
 Mike M
Mike M
NOEL
NOEL
matt
matt
Are you a Cnet Computer and Internet Expert? Answer questions, earn points and help others
