Question about Altec Lansing Inmotion-IM600 (0021986954446) Docking Station
Altec lansing IM600 low battery even when plugged in
I have my Altec Lansing in motion IM600 plugged in with the AC adapter but when I turn it on the low battery light starts blinking. After a minute or two of music the entire system shuts off even though it is indeed connected to AC power adapter. I have had these speakers for years and this problem just started.
5 Related Answers
Anonymous
SOURCE: Remote Control Altec Lansing IM600 - Battery
Turn the remote upside down. At the bottom, there is a slot that opens the battery tray and a series of grooves that are part of a clip that releases the tray. Insert the fingernail of your thumb into the grooves and the fingernail of your index finger into the slot. Ease the grooves (clip) toward the middle of the remote and slide the tray out. There is a ridge in the tray that matches the battery only when the battery is in the proper position. Slide the tray back in. If the remote doesn't work, you've probably inserted the battery in the wrong position.
Posted on Feb 16, 2009
Anonymous
SOURCE: Wrong Power Supply
If it doesn't work with batteries or the supplied power supply than your speakers are fried. Sorry for the bad news.
Posted on Mar 03, 2009
Anonymous
SOURCE: lost cord!
I have them for sale AC Adapter For Altec Lansing speakers inMotion iM600.Price is $15.95 Plus $6.95 shipping . send me your email and address to this email [email protected] and I will invoice you through paypal. Thanks
Posted on Mar 29, 2009
Anonymous
SOURCE: Where to find a speaker replacement for InMotion IM600
hi,i have 2 speakers salvage from im600 [email protected]
Posted on Apr 27, 2010
SOURCE: I have altec lansing imt402 and so sound comes out
audio amplifier IC damaged
Posted on May 14, 2010
AC adapter not charging system
check with multimeter on Volts DC if there is any voltage on Adapter pin, if there is no voltage then you need new adapter
My Altec Lansing Inmotion used to charge my Ipod Touch, but since yesterdag (after not using it for 3 weeks) it won't charge my Ipod anymore. The Altec charges itself, but somehow the Ipod doesn't. It is...
That is a tough one. Is your iPod fully seated -- will it play music in the im600? Have you tried a different iPod in the im600 to see if it charges? Does your iPod recharge normally in other players, in a wall charger and your computer? If not, your iPod could possibly need a new battery.
Also: since it was unplugged for 3 weeks, you may just need to run the im600 through a full cycle or two (let the FM radio play until the battery is dead, with no iPod in it), then recharge the im600 for 5 or 6 hours, and THEN mount your iPod into it and see if it charges it. Be sure to unplug/plug-in the adapter into the im600 to ensure it is getting full power from the wall outlet. One last thing: the im600 will only charge the iPod when it is plugged into AC power; it won't charge the iPod while it's running on its own battery power. Good luck!
2answers
In Motion im600 unit seems to work for a few hours then just shuts down. If I wait a day or two it will start working again, then only for maybe a few hours. I've taken the battery out for a while then put...
5V AC adapter for Altec Lansing inMotion iM600 speakers http://lcdpayless.com/productpage.php?productId=172
13V AC adapter for Altec Lansing inMotion iM600 speaker http://lcdpayless.com/productpage.php?productId=170
4helpful
2answers
I need to replace the Ion Battery for the Altec Lansing IM600
2 screws at the back removed with a cross head screwdriver. Remove the casing, then the battery plugs in to a white connector.
2answers
1helpful
2answers
Lost cord!
2answers
Poor FM reception with Altec Lansing IM600 when using ac adapter
here is what I recommend, and It may be irrelevant but it could work.
the ac adapter cable may be creating interference with the radio signal, so what you can do is go ahead and try connecting the ac adapter as far away as possible from the device in a way that the( keep the cable as far away from the device, just leaving the plug into the hole)
and try putting some antistatic tape onto the end that goes into the device.
good day
Altec Lansing iM600
I have read the user manual for this product and it seemes to me you may have a defective battery.
Altec Lansing Inmotion-IM600 (0021986954446) Docking Station Logo
Top Altec Lansing Audio Players & Recorders Experts
Steve Sweetleaf
Steve Sweetleaf
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
