Samsung 510N 15" Flat Panel LCD Monitor Logo
Posted on Oct 11, 2007
Samsung SyncMaster 510N
Monitor is working Properly , but It suddenly starts Blinking like a Tubelight. Monitor is Fluctuating.
  • 1 more comment
  • Anonymous Dec 22, 2007
    Me to having same problem with the same monitor. Mine is of 2 years old and worked well till recently. The problem began some one month back. I didn't care abt it first but began to worry when it became a continuous feature. First I tried small solutions like keeping speakers at more distant to the monitor, checking for loose connections etc..., which didn't help. I searched many tech forums but could not find any solution. First of all I could not describe my actual problem, because monitor is working good except the blinking problem. All others who claim their problem as 'blinking' describe about 'going black and coming to life for ten or more seconds and then working properly..., or going off and on...,' like that. But in my case monitor is working properly. It is only after seeing nitin's description 'blingking like tube light' in "FixYa" that I could match my problem. That with the same monitor. But disappointed when I see no solution. But expecting some solution soon as I found here what exactly my problem is.
  • Anonymous Jan 28, 2008
    i have the same model Sync-Master 512N from Samsung, which was working fine since two years but recently it has started blinking dim and light.
  • crimso Mar 01, 2008
    Iam also having the same problem with my microtek monitor. When switched on, it started with dim & bright initially but comes to normal after sometime. After few months the monitor now works rarely. Many times when switched ON, the front LED blinks making tick sounds and then it takes time to display. May be 10mins or even an hr . the time varies. Once the LED stops ticking then the monitor starts slowly from dim to normal. and some times it remains dim.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 01, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
477
Points
Its time for u poeple to buy a new moniter .....or get it repaired by a prof tecnician.....the electrons which bambard on the picture tube at a point of time they become weak...n they loose there capacity......so the moniter starts dim and after wards when the moniter heats up it get fine !!!!!!!!!!!!!!!
My moniter isnot open as soon i start pc it is blinking and after some time it get startes automatically
This is no a monitor problem, you should have problem with your Video Card, or Mother Board if you use the Built In Video, remember that a monitor is blinking while wait VGA signal from computer.
You can check too the VGA Cable to discart...
I have a SyncMaster 510N, where i find flickering problem. But display is okay. I difficult to view the screen. Is this major issue?
power cable and data cable connection may be loose
tight it
2. your wall socket of power may not having earth connection properly
Samsung SyncMaster 510N Monitor is flickering and blinking like a Tube Light After playing games for 20-30 min . It flickers when some darkness comes PLEEEZE help me
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
rahul
3answers
Samsung SyncMaster 510N LCD TFT Monitor
Samir
Samsung SyncMaster 510N 15 not optimum mode
There is an issue with the microcontroller with 510N LCD monitors. Get it repaired at samsung service center.
3helpful
Display Resolution
samsung syncmaster 510N nonoptimize mode recomended mode :-1024x768 60hz how can i fix this?
Top Samsung Computers & Internet Experts
Marvin
Marvin
ZJ Limited
ZJ Limited
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
