1996 Lincoln Town Car Logo
Posted on May 08, 2009
I need help I changed the key door code on my 1996 Lincoln
Someone has gotten a hold of the code and now I need to change it again can you PLEASE help me on how to do this?
Thanks,
Leslee
Terry Huffman
Level 1:
  • Contributor 36 Answers
  • Posted on May 09, 2009
Terry Huffman
Contributor
Level 1:
Answers
36
Questions
0
Helped
10433
Points
77
1. Enter the original factory code, 2. within 5 seconds, press1/2 3. within 5 seconds enter your chosen new 5 digit code, pressing each digit within 5 seconds of the previous. 4. all of the doors will lock and then unlock to confirm programming of the new code. you can now use either factory or this new code. 6. To erase all of the personal entry codes and remote transmitters programmed - 1. Enter the factory code 2. press 1/2 within 5 seconds 3. press and hold 1/2 for two seconds
1996 Saab 900 Radio Won't Accept Code
unhook the battery for an hour or so to fully clear any previously bad entry attempts. hook battery back up and try the code again
2answers
I need the unlock code for my 1996 Lincoln Contenental. I locked my keys in the car and cannot get ahold of the previous owners.
start by contacting a dealer with proof of ownership in your hand. they will put you in contact with a factory tech rep. a prior owner is going to do you no good.
What would you do when your 1996 lincoln town car doors won't lock with the key. And the trunk won't open.
How can a lock not lock or unlock with a physical key? Maybe the cylinders are frozen? Try squirting a little oil into the locks.
1996 Town Cars have keys and keyless entry. The physical keys are two, an ignition key and a door key. You can't use the door key in the ignition, nor the ignition key in the door. They aren't interchangeable.
The default key code for keyless entry is posted on the right trunk hinge, inside the trunk.
5helpful
2answers
Need to find a way to disarm alarm for Ford Contour Sport, 1996. Also it will not start
Many Ford trucks, vans and suvs use PATs (passive anti-theft) keys. These keys prevent someone from copying your key to a blank and using the blank. There is a small chip in the key which the vehicle must recognize before it will start.
PATS is Ford Motor Company's passive anti theft system. In 1996 it started showing up on select models of Ford and Lincoln Mercury vehicles. The keys for these vehicles have a tiny radio frequency transponder imbedded in the plastic Head.
pats_key.gifWhen you attempt to start the vehicle, the onboard computer sends out a RF signal that is picked up by the transponder in the key. The transponder then returns a unique RF signal to the vehicle's computer, giving it the ok for the vehicle to start and continue to run. This all happens in less than a second, and is completely transparent to the vehicle operator. It is a very effective system that does its job without the vehicle owner having to think about it, or modify his / her usual routine.
The PATs key is used on the following Ford family trucks and SUVS:
1998-up F-150
1998-up Expedition
2000-up Excursion
1998-up Explorer
1998-up Ranger
1998-up Lincoln Navigator
1998-up Mercury Mountaineer
Additionally, PATs can be found on the follow Ford family cars and mini-vans:
1998-up Contour
1997-up Crown Victoria
1999-up Escort
2000-up Focus
1996-up Mustang and Taurus
1998-up Windstar
1998-up 2000-up Lincoln LS
1998-up Lincoln Mark VIII, Lincoln Continental and Lincoln Town Car
1997-up Mercury Grand Marquis
1998-up Mercury Mystique
1996-up Mercury Sable
Following are the instructions for programming a blank key (you must have at least one working key for this procedure).
The PAT
1. Make sure you have both keys.
2. Turn on car but don't start. Watch "theft" indicator untils it goes out.
3. Turn off and repeat procedure with second key.
4. After "theft light goes out, insert new key and turn on.
5. Wait until the theft indicator goes off and then turn off switch.
6. Wait thirty seconds. New key is now programmed into security module. Repeat for any other keys.
1. Erase any old codes by entering the factory code.(buttons will light up)
2. Press 1/2 button within 5 seconds.
3. Press 7/8 and 9/0 buttons at the same time within 5 seconds.
To set new code:
1. Enter factory code (numbers will light up)
3. Enter personal 5 digit code(decide beforehand) within 5 seconds of each previous one.
To unlock all the doors,press the 3/4 button within 5 seconds of the driver door unlocking.
To lock all doors and set alarm system,press 7/8 and 9/0 at the same time.
To disarm or reset a triggered alarm,just enter personal or factory code.
Do not set a code with five of the same consecutive numbers. It's too easy for thieves to figure out.
Deactivating and Activating Autolock
To deactivate the "autolock":
With all doors and tailgate closed but NOT locked,and ignition OFF.
1. Enter 5 digit code
2. While holding 7/8 button in, press and release the 3/4 button.
3. Release 7/8 button
The horn will chirp once if the "autolock" was deactivated
or two times if "autolock" was activated.
To reactivate the system,repeat steps 1 thru 3
Alternate Method To Deactivate And Activate Autolock
Do steps [1] through [5] (below) within 30 seconds or you'll have to do it over. If you have to do it over, wait 30 seconds between attempts.
Close all doors securely.
1.Turn the ignition key to ON.
2.Press the power door UNLOCK control THREE times.
3.Turn the ignition key from ON to OFF.
4.Press the power door UNLOCK control THREE times.
5.Turn the ignition key back to ON .The doors should lock and unlock.
6.Press the power door UNLOCK control. The horn should chirp ONCE to confirm successful switching of the autolock system.
Hope this help you (remember comment and rates this).
1helpful
I would like to know to how to change the combination for the door entry.
you need the factory code to change the code. Actually what you are doing is adding a second code the factory code is always there and can't be changed it is usually located on the trunk hinge on pass side
5helpful
My check engine light does not flash when i turn key before start
bulb is probably blown... you have to remove the instrument cluster to change the bulb
2helpful
I have a 1993 town exec.how do i change the door security code
call ford with the vin they may be able to help you get the code
Top Lincoln Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
