R
Ryan Brosseau Posted on Jan 12, 2018
Bose companion 2 sound cuts out
Companion 2 speakers are about 2 years old, they will work fine for about 30 minutes and then the sound abruptly stops. If I turn them off and then back on they will work again for about 30 minutes until the process repeats. I have replaced the output cable, and they do not exhibit any other symptoms.
Michael Elliott
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 12, 2018
Michael Elliott
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1221
Points
6
Suggest you check the power plug connection for possibly slowly overheating, cutting out and reworking when cooler..swtch everything off befre fiddling with the power though. .safety first!
1 Related Answer
Anonymous
  • Posted on Aug 03, 2010
SOURCE: My Bose Companion 3 coputer speakers are 2 years
i hav the same problem but all three shut off ,and i have to shut off and turn on again
No Sound At all from the Speakers. I have plugged and replugged in the connections. I am getting power but absolutely nothing out of the speakers. Some minor static if I wiggle the power cord,...
no sound at all it was working fine before i got additional speakers creative sarrounding withe 2 mini and 1 sub buffer how to test it its just not comming on now
Bose companion 2 laptop speakers quit working
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow? right click re-install drivers
hope this helps good luck
Problem hooking up bose speakers
mcdevito75 here, The HP speakers that came with your computer work fine, the bose speakers work fine on your other computer, the plug on the Bose speakers is a little shorter than the HP speakers, and only the right Boss speaker is working, HMM, Check the Bose speakers, both of them for a volume control 1 of them may need adjustment on this particular computer. If that"s not it, I would speak to a Radio Shack, Staples etc.
Sound keeps cutting out. Have to reboot to get back. Please help
you can try uninstalling and reinstalling the drivers,or also try to update it
12helpful
Would like to know how to open speaker cabiant.Bose companion 2.
currently trouble shooting Bose Companion 2 computer speakers, no sound from speaker, would like to know how to open cabinet to see if wires are attached to speaker?
Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
BOSE speakers won't work with my HP Pavilion Desktop......help!
try reinstalling the software for them then make sure your sound card drivers are installed properly
Bose Companion 3 - Is getting power but no sound
Are you using the usb cable to power the speakers?
2helpful
Bose Companion II Computer Speaker: The AC power adapter burnt
My puppy chewed through the cord for my a/c adapter, I just took the speakers into Circuit City, and they found me a workable replacement (the replacement isn't BOSE, but it works just fine).  Hope that helps!
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
