Sony CDX-M610 CD Player Logo
Posted on Oct 10, 2007
Sony cdx m610
The stereo is on but when it closes it will not light up on the face. It will also not open any more. The open and close buttons are not working. when it is open the lights work on the open face. I took out the stereo to make sure it was all connected and there didnt seem to be any problems...Also there is static when I listen to the radio
please help
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Oct 10, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1509
Points
8
The ribbon that connects the faceplate to the main unit has gone bad from flexing back and forth and will need to be replaced.
12helpful
3answers
I lost code for my sony cdx-m610 head unit
My M610 has a code try - off, source, att, openclose on the remote.
Have a sony cdxm610 faceplate won't close and has no power.
WHITE AND ORANGE WIRE IS FOR ILLUMINATION WHICH IS NOT NEEDED IN INSTALL. LIGHT BLUE IS FOR POWER ANTENNA AND THE LIME GREEN SHOULD BE FOR LEFT REAR SPEAKER( SOLID GREEN IS POSITIVE AND GREEN WITH BLACK STRIP IS NEGATIVE)
2helpful
3answers
Sony cdx-m610 BIG PROBLEM
yal ever fix them? its the ribbon cable between the face and the circuit board inside the unit the ribbbon cable is very cheap on ebay just google for example cdx-m610 ribbon cable now for the repair close ur face before u take out ur radio assuming u guys still have ur remote to do so theres 3 screws on the bottom of the face when u go to carefully pop the front panel off after pullin them hold ur deck facing down (this will keep ur reset and open buttons from fallin out then theres 4 screws holding in the face's circuit board roll the board out of the face very very carefully pry open the little black lock holding the cable in the connector then open ur radio up pull out the cd player assy same thing with that connector then ull notice the cable goes thru a tension roller pull each end of the cable to unroll it hold it there while removing the cable and sliding in the new one then slowly let go of the roller reattach the cable ends and put everything back together with the face remember its easiest to hold the deck face down those 2 buttons will stay in place hook the top of the face's cover first then put the deck back in ur ride and enjoy these ol sonys r worth a $20 fix specially if they still work good hope this helps yal
1helpful
Sony cdx m610 car stereo
sound - mode - att - open/close
pres buttons buy this order.
4answers
Can u help us m8
contact the dealer of where you bought your stereo...or maybe the sony company...:)
2answers
Sony CDX-M630
not open the face? or not get on the stereo? if not open the face maybe is too fit on the space for the stereo, check down if have space, if dont get on, check if are well conected
2helpful
6answers
Sony CDX M8800 Front Panel Problem
u need 2 replace the ribbon that goes to the panel to the unit.i had the same problem with mine then i went on to ebay and found the ribbon there (cdx-m8800 repair kit)hope this helps
Top Sony Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
