Samsung YP-K3 MP3 Player Logo
Posted on Oct 10, 2007
I re-booted my computer and lost all software to my mp3 player
I re booted the whole system to get rid of viruses but I've lost my disk to re install my mp3 samsung. Do you know where i can get a disk to re install it?
  • 1 more comment
  • nanii Nov 10, 2007
    i lost my disk for my yp-k3 samsung mp3 player
  • Anonymous Dec 27, 2007
    i lost my disk in a move....
  • bridlez Jan 25, 2008
    no install disk
Anonymous
Level 1:
  • Contributor 70 Answers
  • Posted on Feb 05, 2008
Anonymous
Contributor
Level 1:
Answers
70
Questions
0
Helped
62292
Points
66
YOu can get hold of the software from the Samsung website - support section. YOu will find updated software and firmware which should allow your unit to work better
Lost songs on iPod Classic
First off, whenever working with new software for your stuff, best to bak up your tunes......HOWEVER....all is not lost....you MAY be able to recover by removing the hdd on the old computer, copy you audios....most should be there and intact, unless the virus attacked those.....so copy those files to a clean hdd, then scan it for viruses....then you should be fine...plz post back
My hp pavilion dv7-4285dx has lost everything, os and all. How can I get it to read the recovery disc I ordered from HP?
What makes you think you've lost everything? Unless you specifically instructed your computer to Format the hard drive, I would doubt very seriously that you have lost everything. Everything might still be there, but a virus has hidden it to make you think you've lost everything. Oh, one more way to lose everything is to interrupt a System Recovery before it completes, or interrupt an Fresh Install of Windows before it completes.
A lot of times the System will think you've lost everything because somehow a setting the bios was changed either by you or some virus and it has set the hard drive where it is not detectable. Turn your computer off then watch the screen to see which key you have to hit to get into the BIOS or SETUP or System Setup.
Once you are in the BIOS scroll through it looking for AHCI that will be associated with disk drives or disk controllers. If it is Enabled, Disable it and Boot your machine. If it is Disabled, Enable it and Boot your machine. In other words just change the settings for AHCI.
Do that and report back.
2answers
How to rid my computer of viruses
Use any Anti-virus scanner.
To start with you can use any trialware version of prominent anti-virus companies, like
norton
mcafee
bit defender
avg
you can try download.com to find free and trial based anti-virus programs.
Updating your virus scanner definitions regularly would minimize chances of getting infected again if your virus scanner is good.
1helpful
AC'97 Audio Codecs Blue screen of death on install please help me fix this problem thanks dell dimension 2350
This usually means your HD has a virus. It could be a boot virus. The best way to get rid of it is to completely reinstall your OS. When you turn on your computer put in your OS software or recovery software (if software recovery does not work you will have to put on new version of OS from another disk). After you put the disk in, restart your computer and hit Enter when the screen prompts to Boot from CD...
If this does not work, you can purchase a anti-boot virus software from your local comp store, otherwise you may need a new HD. But try reinstalling the OS from scratch, that is the best way.
1helpful
2answers
DVD Player Infected By Virus When Using Pen Drive
I think it is a DVD player with hard disk?
Look for an option to format the disk.
That way you can get rid of the virus.
1helpful
I plug in my mp3 player and my whole computer freezes!!!
if that hapens then your sansa is infected with virus or your computer is infected. try installing an original anti virus in your system and clean up your device and your system...and also format the device
My 4GB pen drive is not formating...
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
2answers
Write protected
4helpful
How to delete songs off Samsung S3 mp3 player?
go to settings then system then format it will ask if you want to format whole memory and you say yes and presto no more songs its kindof the same drift as if you were to format your computer to get rid of viruses and old files that are piling up and such. anywho hope this helps good luck
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
