I have a 1992 dodge shadow.but the windshield wipers isn't working.I checked the motor is well,the terminal voltage is 12V,how can I continu to repair the 1992 dodge shadow's windshield wipers?
Re: I have a 1992 dodge shadow.but the windshield wipers...
You posting is slightly confusing but I gather your windshield wipers stopped working.
The repair method is as follows;
) Check the fuse.
) Check the wiper motor. Turn the wipers on and listen for the hum of the motor.
If you hear the hum then the linkage has probably come loose. You will have to take the covers off
to get to the linkage for the wiper. You can either repair the parts, get salvage yard parts or replace with new part$.
If you donot hear the motor hum then you should verify electricity is getting to the motor. A simple
voltmeter can be used. If the motor is bad you can replace it. Call some auto supply stores for after-market motors or call salvage yards for parts.
If the windshield wipers on your 2002 Corvette won't shut off, it could indicate a problem with the wiper control switch or a malfunction in the wiper motor circuit. Here are some troubleshooting steps you can try:
Check the wiper control switch: Ensure that the wiper control switch is in the "Off" position. Sometimes, the switch can get stuck or malfunction, causing the wipers to stay on. Try moving the switch back and forth a few times to see if that resolves the issue.
Inspect the wiper motor relay: The wiper motor relay controls the power supply to the wiper motor. If the relay gets stuck or fails, it can cause the wipers to stay on. Locate the wiper motor relay in the fuse box or relay panel and try replacing it with a known working relay of the same type to see if that resolves the issue.
Check the wiper motor circuit: The wiper motor circuit may have a short or an electrical problem that is keeping the wipers engaged. Inspect the wiring harness connected to the wiper motor for any signs of damage or loose connections. Use a multimeter to check for continuity and proper voltage in the circuit. If you are not familiar with automotive electrical systems, it is advisable to consult a professional technician or a qualified electrician.
Disconnect the battery: As a temporary solution, you can disconnect the negative terminal of the car battery to stop the wipers from running. This will disable other electrical components as well, so it's recommended as a temporary measure until the issue can be properly diagnosed and repaired.
Excellent diagnostics by our resident Pro Expert Jeff, which should be down here. It makes the question solved and will appear in a search of the site as 'Solved'. It also gives you points and awards.
Jeff Armer Nov 17, 2021
could be the wiper relay contacts are stuck closed causing power (battery voltage ) to be supplied all the time ,or a problem with the GEM module .
Windshield Wiper
The windshield wiper system consists of the following parts:
Windshield wiper arms (2)
Windshield wiper motor on the air cowl trim panel
Windshield wiper linkage
Windshield wiper blades (2)
Wiper relay, in the central junction box (CJB)
Generic electronic module (GEM)
Wiper/washer switch (part of the multi-function switch), consisting of:
wiper switch
washer switch (pressure switch) and
delay control switch (rotary switch, depending on model)
Inspection and Verification
Verify the customer concern.
Visually inspect for obvious signs of mechanical and electrical damage:
If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
If the cause is not visually evident, connect the scan tool to the data link connector (DLC) and select the vehicle to be tested from the scan tool menu. If the scan tool does not communicate with the vehicle:
check that the program card is correctly installed.
check the connections to the vehicle.
check the ignition switch position.
If the scan tool still does not communicate with the vehicle, refer to the scan tool operating manual.
Carry out the scan tool data link test. If the scan tool responds with:
ISO or CAN circuit fault; all electronic control units no response/not equipped, refer to Section 418-00 .
No response/not equipped for GEM, refer to Section 419-10 .
System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out the self-test diagnostics for the GEM.
If the DTCs retrieved are related to the concern, go to the Generic Electronic Module (GEM) Diagnostic Trouble Code (DTC) Index.
If no DTCs related to the concern are retrieved, GO to Symptom Chart .
B1438 Wiper Mode Select Switch Circuit Failure GEM Go To Pinpoint Test H .
B1446 Wiper Park Sense Circuit Failure GEM Go To Pinpoint Test G .
B1451 Wiper Wash/Delay Switch Circuit Failure GEM Go To Pinpoint Test H .
B1611 Wiper Rear Mode Select Switch Failure GEM Go To Pinpoint Test F .
B2107 Front Wiper Motor Relay Circuit Short To Battery GEM Go To Pinpoint Test H .
B2110 Front Wiper Motor Relay Circuit Open GEM Go To Pinpoint Test H
checking for codes in the gem module mite point you into a diagnostic direction .
The wipers stay on continuously
Wiper/washer switch
Windshield wiper relay
Central junction box (CJB)
Circuitry
Go To Pinpoint Test B .
Pinpoint Test B: The Wipers Stay On Continuously
Normal Operation
When low speed operation is selected, the windshield wiper motor receives voltage through circuit 32-KA10 (WH/GN). When high speed operation is selected, the windshield wiper motor receives voltage through circuit 32-KA11 (WH/BK). When intermittent operation is selected, the generic electronic module (GEM) sends an intermittent ground signal to the windshield wiper relay through circuit 91S-KA12 (BK/WH). The relay energizes and sends voltage to the wiper/washer switch through circuit 32-KA19 (WH/BK). The wiper/washer switch sends voltage to the windshield wiper motor through circuit 32-KA10 (WH/GN). When the wiper/washer switch is turned to the off position, or between intermittent pulses, the internal run/park switch in the windshield wiper motor provides voltage to the windshield wiper relay through circuit 32-KA9 (WH/BU) until the wiper motor completes its cycle and opens the circuit
Possible Causes
Circuit 32-KA10 (WH/GN) short to voltage
Circuit 32-KA11 (WH/BK) short to voltage
Circuit 32-KA19 (WH/BK) short to voltage
Circuit 91S-KA12 (BK/WH) short to ground
Wiper/washer switch
GEM
PINPOINT TEST B: THE WIPERS STAY ON CONTINUOUSLY
Test Step Result / Action to Take
B1 DETERMINE THE WIPE SPEED
Move the wiper lever to the OFF position.
Key in ON position.
Do the windshield wipers move at a fast rate?
Yes
GO to B2 .
No
GO to B4 .
B2 CHECK THE WIPER/WASHER SWITCH FOR NORMAL OPERATION
Key in OFF position.
Disconnect: Wiper/Washer Switch C2081.
Key in ON position.
Yes
GO to B3 .
No
CHECK the wiper/washer switch for correct operation.
Refer to Wiring Diagrams Cell 149 for schematic and connector information.
If necessary, INSTALL a new multi-function switch. REFER to Section 211-05 . TEST the system for normal operation.
B3 CHECK CIRCUIT 32-KA11 (WH/BK) FOR A SHORT TO VOLTAGE
Disconnect: Windshield Wiper Motor C125.
Key in ON position.
Measure the voltage between wiper/washer switch C2081-8, circuit 32-KA11 (WH/BK), harness side and ground.
Is the voltage greater than 10 volts?
Yes
REPAIR the circuit. TEST the system for normal operation.
No
INSTALL a new windshield wiper motor. REFER to Wiper Motor - Windshield in this section. TEST the system for normal operation.
B4 CHECK THE WIPER/WASHER SWITCH FOR NORMAL OPERATION
Key in ON position.
Do the front wipers move at a slow rate?
Yes
GO to B5 .
No
GO to B6 .
B5 CHECK CIRCUIT 32-KA10 (WH/GN) FOR A SHORT TO VOLTAGE
Key in ON position.
Measure the voltage between wiper/washer switch C2081-9, circuit 32-KA10 (WH/GN), harness side and ground.
Yes
No
B6 CARRY OUT THE WIPER/WASHER SWITCH COMPONENT TEST
Carry out the wiper/washer switch component test.
Does the wiper/washer switch pass the component test?
Yes
GO to B7 .
No
B7 CHECK CIRCUIT 32-KA19 (WH/BK) FOR A SHORT TO VOLTAGE
Connect: Wiper/Washer Switch C2081.
Disconnect: CJB C270c.
Key in ON position.
Do the windshield wipers move at a slow rate?
Yes
No
GO to B8 .
B8 CHECK THE CJB FOR A SHORT TO VOLTAGE
Disconnect: Windshield Wiper Relay C2042.
Connect: CJB C270c.
Key in ON position.
Yes
INSTALL a new CJB. TEST the system for normal operation.
No
GO to B9 .
B9 CHECK THE WINDSHIELD WIPER RELAY
Carry out the windshield wiper relay component test.
Does the windshield wiper relay function normally?
Yes
GO to B10 .
No
INSTALL a new windshield wiper relay. TEST the system for normal operation.
B10 CHECK CIRCUIT 91S-KA12 (BK/WH) FOR A SHORT TO GROUND
Connect: Windshield Wiper Relay C2042.
Disconnect: GEM C201e.
Key in ON position.
Yes
No
GO to B11 .
B11 CHECK FOR CORRECT GEM OPERATION
Disconnect all the GEM connectors.
Check for:
corrosion.
pushed-out pins.
Connect all the GEM connectors and make sure they seat correctly.
Operate the system and verify the concern is still present.
Is the concern still present?
Yes
INSTALL a new GEM. REFER to Section 419-10 . TEST the system for normal operation.
No
The system is operating correctly at this time. The concern may have been caused by a loose or corroded connector. CLEAR the DTCs. REPEAT the self-test.
Wiper/Washer System Components
The Wiper/Washer System consists of the following electrical components:
• Accessory relay
• Heated washer nozzles w/XA7
• WASH NOZ 10A fuse
• Windshield washer fluid level switch
• Windshield washer pump motor
• Windshield wiper motor
• Windshield wiper motor module
• Windshield wiper/washer switch
• Wiper/washer switch 10A fuse
• Wiper motor 30A fuse
Wiper/Washer System Operation
The windshield wiper motor module is part of the windshield wiper motor cover and controls wiper motor operation. The accessory voltage supply circuit to the windshield wiper motor assembly is used to operate the wiper motor in all modes. The windshield wiper motor is a 2 speed motor and is operated at low speed in all modes except HIGH. The accessory voltage supply circuit to the windshield wiper/washer switch is used to supply the windshield wiper switch signal circuits. The windshield wiper switch signal circuit voltage levels to the wiper motor module determine the wiper motor operating mode.
When the wiper/washer switch is in the LOW position voltage is supplied through a 24K ohm resistor within the switch to the windshield wiper switch signal 2 circuit, and accessory voltage is supplied to the windshield wiper switch signal 1 circuit. The reduced voltage from the wiper switch signal 2 circuit and accessory voltage from the wiper switch signal 1 circuit causes the wiper motor module to close the wiper motor accessory voltage supply circuit to the wiper motor low speed terminal.
Principles of Operation
The windshield wiper motor receive inputs from the following:
multifunction switch
lighting control module (LCM)
ignition switch
battery junction box (BJB)
The following components are integrated into the windshield wiper motor:
high/low speed relay
run/park sensor (Hall effect)
washer pump relay
High Speed Windshield Wipers
High speed is activated when the multifunction switch supplies ground to the windshield wiper motor module inputs. The windshield wiper motor module then supplies ground to the run/park sensor and high/low relay coil, activating the relay with voltage supplied from the ignition switch (RUN/ACC) through the central junction box (CJB). When the windshield wiper motor module receives voltage from the run/park sensor, it removes ground from the run/park sensor, deactivating it. The windshield wiper motor continues to operate from voltage connected through the run/park sensor until the Hall effect senses the magnet in the motor. When the Hall effect senses the magnet in motor the windshield wiper motor returns to the park position, the internal run/park sensor grounds the windshield wiper motor module input and the windshield wiper motor module removes ground from the windshield wiper high/low relay coil, deactivating the high/low relay and windshield wiper motor. The windshield wiper motor module continues to cycle the windshield wipers until the inputs from the multifunction switch are changed from the high speed position. Low Speed Windshield Wipers
Low speed is activated when the multifunction switch supplies a specific ground to the speed inputs of the windshield wiper motor module. The windshield wiper motor module then supplies ground to only the windshield wiper run/park relay coil, activating it. When the windshield wiper run/park relay is activated, the deactivated windshield high/low relay connects voltage to the windshield wiper motor low input activating the wiper motor. The windshield wiper motor module continues to operate the windshield wiper motor in the same manner as in high speed, but in low speed with the wiper motor connected to the low speed input. Intermittent Speed Windshield Wipers
The intermittent wiper speed is activated with grounds controlled by the multifunction switch inputs to the windshield wiper motor module. The windshield wiper motor module then activates the windshield wiper run/park relay coil and switches voltage through the windshield wiper high/low relay. The high/low relay remains deactivated, supplying the voltage to the wiper motor low speed input and activates the windshield wiper motor. When the windshield wiper motor module receives the grounded input, the motor continues to operate until Hall effect sensors senses the wiper motors magnet, which turns off the run/park sensor output to the windshield wiper run/park software, deactivating the relay and disconnecting voltage to the wiper motor. The windshield wipers remain parked until the windshield wiper motor module completes a time-out and then repeats the intermittent windshield wiper cycle. Washer System
The windshield washer is activated by the internal wiper motor module when it receives a ground from the multifunction switch between the washer input. Dependent on the correct ground, the internal wiper motor modules activates the windshield washer relay (internal) by grounding the respective relay coil. When the relay is activated, it connects voltage to the washer pump while the washer level switch provides ground to the washer pump. Default Mode
The windshield wiper motor defaults to this mode when the run/park sensor does not sense the hall effect magnet inside wiper motor. This can be caused by obstruction of the windshield wipers or a binding linkage. The windshield wiper motor will continue to operate in a high/low speed condition for a period of 60 seconds.
Symptom Chart
Symptom Chart
Condition
Possible Sources
Action
The wipers are inoperative
Multifunction switch
Circuitry
Ignition switch
Go To Pinpoint Test A .
Do you know how to test automotive electrical circuits using a factory diagnostic test procedure flow chart ?
PINPOINT TEST A: THE WIPERS ARE INOPERATIVE
Test Step
A1 CHECK CIRCUITS 65 (DG) AND 2025 (RD/YE) FOR VOLTAGE
Key in ON position.
Measure the voltage between windshield wiper C125 pin 5, circuit 2025 (RD/YE), harness side and ground; and between windshield wiper motor C125 pin 8, circuit 65 (DG), harness side and ground.
Are the voltages greater than 10 volts?
Yes
GO to A2 .
No
REPAIR the circuit(s) in question. TEST the system for normal operation.
A2 CHECK CIRCUITS 57 (BK) AND 676 (PK/OG) FOR OPENS
Measure the resistance between windshield wiper C125 pin 6, circuit 57 (BK), harness side and ground; and between windshield wiper motor C125 pin 3, circuit 676 (PK/OG), harness side and ground.
Are the resistances less than 5 ohms?
Yes
GO to A3 .
No
A3 CHECK THE MULTIFUNCTION SWITCH
Disconnect: Multifunction Switch C202b.
Carry out the multifunction switch component test.
Does the multifunction switch pass the component test?
Yes
GO to A4 .
No
INSTALL a new multifunction switch. REFER to Section 211-05 .
A4 CHECK CIRCUIT 57 (BK) FOR AN OPEN
Measure the resistance between C202b pin 5, circuit 57 (BK), harness side and ground.
Is the resistance less than 5 ohms?
Yes
GO to A5 .
No
A5 CHECK CIRCUITS 56 (DB/OG), 58 (WH), 61 (YE/RD), AND 63 (RD) FOR OPENS
Using the following table, measure the resistance between the multifunction switch C202b harness side and the windshield wiper motor C125 harness side:
No
A6 CHECK FOR CORRECT WIPER MOTOR OPERATION
Disconnect all wiper motor connectors.
Check for:
corrosion
pushed-out pins
Connect all wiper motor connectors and make sure they seat correctly.
Yes
GO to A7 .
No
The system is operating correctly at this time. The concern may have been caused by a loose or corroded connector. TEST the system for normal operation.
A7 CHECK THE WINDSHIELD WIPER MOTOR
Carry out the windshield wiper motor component test as outlined in this section.
Does the windshield wiper motor pass the component test?
Yes
The system is operating correctly at this time. The concern may have been caused by binding or incorrect pivot arm adjustment. REFER to Windshield Wiper Blade and Pivot Arm Adjustment in this section. TEST the system for normal operation.
No
INSTALL a new windshield wiper motor. REFER to Windshield Wiper Motor in this section.
First you need a wiring diagram, free at http://www.bbbind.com/free_tsb.html Then you need a DVOM - digital volt ohm meter to test the circuit . Then if your not familiar with automotive electrical systems testing ,go on youtube an check out Electric Testing Techniques You Need to Know Also having a factory diagnostic trouble shooting chart would also be usefull . You could just start replacing parts , you mite get lucky . The wiper motor is a high fail part , so is the switch ..You could find the fuse is blown ! But fuse's don't usually blow without a reason . Short to ground , low resistance . ( high current flow) Also knowing how they work and what all is involved in making them work.
The Wiper/Washer System consists of the following components:
• FRT/WPR/WSHR 25A fuse
The windshield wiper motor module is part of the windshield wiper motor cover and controls wiper motor operation. The windshield wiper motor is a 2 speed motor and is operated at low speed in all modes except HIGH. The accessory voltage supply circuit to the windshield wiper motor assembly is used to operate the wiper motor in all of the low speed modes. The accessory voltage supply circuit to the windshield wiper/washer switch is used to supply the windshield wiper switch signal circuits and the wiper motor high speed circuit.
Windshield wiper/washer system MIST operation is identical to LOW operation except that the MIST switch is a press and release type. When the wiper switch is moved to the MIST position and released, low speed wiper motor operation is started and will continue until 1 cycle is complete. If the wiper switch is moved to the MIST position and held, the windshield wiper motor will operate in the LOW mode until the switch is released.
Don't the wipers work in any mode ?
Did you review the Wiper/Washer System description and operation and perform the necessary inspections?
YES - Go to Step 2
NO - Go to Symptoms - Wiper/Washer Systems
Turn ON the ignition , with the engine OFF.
Operate the windshield wiper/washer switch through all the switch positions.
Does the windshield wiper/washer system operate normally?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 3
Turn OFF the ignition.
Disconnect the harness connector of the windshield wiper motor.
Turn the ignition ON, with the engine OFF.
Connect a test lamp from the accessory voltage circuit of the windshield wiper motor to a good ground.
Does the test lamp illuminate?
YES - Go to Step 4
NO - Go to Step 13
Connect a test lamp from the accessory voltage circuit to the ground circuit of the windshield wiper motor.
YES - Go to Step 5
NO - Go to Step 14
5
Connect a test lamp from the signal 2 circuit of the windshield wiper switch to a good ground.
Press the windshield washer switch.
YES - Go to Step 11
NO - Go to Step 6
Let me know if you make it this far and i will send rest of diagnostic's
Check the wiper arm motor under the hood. Sometimes its the fuse, Check the circuit breaker for continuity across the terminals If an open circuit is indicated replace the circuit breaker. Also check between the circuit motor and the ground, and check the battery voltage with ignition on (don't start) if it test for voltage good and the motor still don't work its a faulty wiper motor. A used wiper motor will work as well as a new $$$$$$ one.Denton auto salvage 785-437-2223 test all their parts for working condition before shipping and have a 30 day return on them
assuming the fuse is good, you can test the wiper motor by applying ground and 12v from the battery directly to the wiper motor. ensure you have the correct terminals on the motor for ground and power. there will usually be 2 or 3 power terminals and 1 ground terminal which has a black wire connected to it. the other terminals are for the different speeds and supply different voltages. you can connect to any of these wires. if the motor works then the switch is bad.
