Washing Machines Logo
Posted on May 07, 2009
Bought bosch aquatak 100 pressure washer. No manual or instructions in box. Store bought at cannot help.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1010
Points
Contact Bosch directly, they have been very helpful in the past.
Robert Bosch (Australia) Pty Ltd
1555 Centre Road
Clayton, VIC 3168
Phone: (03) 9541 5555
Fax: (03) 9543 5485
I have Bosch aquatak 100, i only used it 3x, in the 4th time, its motor continue to work even if i stop pulling the trigger and I think its pressure reduced vs the last time I used it.
It sounds like there may be an issue with your Bosch Aquatak 100 pressure washer. Here are a few possible causes of the symptoms you described:
  1. Clogged nozzle: If the nozzle at the end of the pressure washer wand is clogged, it can cause the pressure to drop and the motor to continue running even when you release the trigger. Try cleaning the nozzle with a needle or a thin wire to remove any debris that may be blocking the flow of water.
  2. Worn pump seals: If the seals in the pump are worn, it can cause a loss of pressure and the motor to continue running. You may need to have the pump seals replaced by a qualified repair technician.
  3. Stuck unloader valve: The unloader valve is responsible for regulating the flow of water through the pump. If the valve is stuck, it can cause the pressure to drop and the motor to continue running. You may need to have the unloader valve repaired or replaced by a qualified repair technician.
  4. Other issues: There could be other issues with the pressure washer that are causing the symptoms you described. For example, there may be a problem with the motor itself or with the electrical connections. In this case, it is best to seek the help of a qualified repair technician who can diagnose and fix the problem.
I hope this information is helpful. If you have any further questions or need additional assistance, don't hesitate to ask.
1helpful
What is the quantity & the type of oil of Bosch Aquatak 10 pressure washer? Thanks
The link has changed in the meantime i see
You can use every EP zinc-free hydraulic oil what you want for it PERLUS ZF46 is a very good alternative
Jun 19, 2016 • Garden
2helpful
2answers
My pressure washer appears to have died.
does the motor have rust in it??the motor can be replaced
Shampoo will not come through
remove pressure nozzle or use low pressure nozzle only for shampoo
Motor smokes
clean water filter out, not enough water coming out to cool the motor
Bosch aquatak
First off check your pressure wand / water nozzle make sure it's clean. if that doesn't help then it could be your water pump.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/anthony_e4f197748c31eabd
Jan 14, 2018 • Garden
Bosch aquatak power washer will not start
Check to make sure the outlet (power supply) is energized. This piece of equipment is supposed to be used on a ground-fault protected circuit, so make sure the ground-fault on the outlet didn't trip or the circuit breaker (fuse) at the electric panel did not trip (or blow)
Check to make sure you are going through the proper starting procedures as outlined in your user's manual on page 8.
Follow the troubleshooting tips on page 10 of the user's manual.
Beyond that, Bosch requires that you have your power washer repaired at an authorized / qualified repair center.
I did locate a web site that shows an exploded parts view of the pressure washer, if that helps. http://www.magic-parts.co.uk/acatalog/BOSCH-Aquatak-1200-Plus.php
In case you don't have a user's manual, you can view it at: http://www.manualslib.com/manual/537062/Bosch-Aquatak-110.html#manual
Best wishes on your project.
A blockage in the inlet of an aquatak 115 plus.
nothing to worry about could be due to water intake,wear on nozzle or just the gauge
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
