Question about Canon Rebel XT / EOS 350D Digital Camera
I removed my CF card to download the images and now cannot reinstall it. I tried a second card and it will not install either.
  • Anonymous May 07, 2009
    Hi, yes you have it. I just looked down the cavity with a magnifier and there was one bent pin. How that could happen, I do not know, but it was.
    I figured, what the heck, and got a jewelers screwdriver and was able to straighten it which was a real surprise to me. I really didn't believe that I could do that.
    Anyway, thanks much for your interest in my problem and maybe this will help someone else.
    Paul
  • Mike Johnson
    Mike Johnson May 11, 2010
    Are any of the pins bent??? is the ejector button stuck in the out possion?
I found one pin bent inside the cavity for the CF card. I carefully used a small jewelers screwdriver to straighten it and then reinserted the card. It worked, which surprised me.
Posted on May 08, 2009
I get a memory card error even though it has a card installed
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
Issue: Memory card Error
Solution: Try a different memory card and/or Reformat memory card PowerShot A70
Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
  1. Turn the power on.
  2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
  3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
  4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
    • To cancel formatting instead, select [Cancel] and press the <SET> button.
    • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
  5. Press the <MENU> button.
  • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
  • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
  • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
Aug 03, 2010 | Canon PowerShot A70 Digital Camera
DSLR - Camera stuck in formatting mode
Hi!
if you want use the 4G you make sure your memory cards is compatible to 4G. then now you have got stuck when you back the 512!? all you have to do is to reformat your camera in to software. Thanks!!!
Nov 02, 2007 | Nikon D70 Digital Camera with 18-50mm Lens
Tip
How to recover photos from CF Card?
CF card is widely used by digital camerafor its larger , from about 512MB to 64GB, lower cost as well as fasterspeed, which allows digital camera shoot under special conditions, such asmoving objects. The most popular and trusted brands for CF Cards includingKingston, Ritek Ridata, SanDisk, Transcend, Apacer, Viking, and Lexar.
Reasonsof lost photos
Lost photos in CF cards can be caused bymany reasons: card damage, failure, corrupt, etc. and the following are some typicalphenomena.
1.
Accidently selected "Format" onyour digital camera and erased all the pictures on the CF card.
2.
Keeping take photographs whenthe camera battery is at the end of its life.
3.
When upload images to computer,mistakenly judge the finish of uploading and eject the CF card ahead of time.
4.
Turning off the camera beforethe image is completely written to the CF Card
5.
Receiving an error message like"card not formatted", "card not found" or "no images found"......
How to recover lost photos from CF card?
Before recovery, you should know that yourphotos are not erased actually. It stored on CF card as a file. When you formatthe card or deleted photos from the card, the data on which the images werestored is not deleted. It only allows new pictures to take its place.Therefore, make sure not taking new photographs any more in case that theprevious photos would be overwritten.
Data Recovery program like Card DataRecovery can help you get backpictures from CF Card easily. Download Card Data Recovery and Install it onyour PC. Take out the CF card from digital camera and connect it to your laptopor connect digital camera to PC directly. (If your desktop or laptop has abuilt-in card reader, things will be much easier, if not, you need a cardreader to help you.) Then your CF card appears as a drive letter when you go to"My computer" If you see this, it means Card Data Recovery can access andrecover your pictures. Select "photo" and scan your CF card. The process isquick and all recoverable images will be listed with the same signature. Previewthe photos before recovery and restore what you wanted.
Besides retrieve photos, Card Data Recoveryalso can recover video, music, files, etc. Popular video and audio formats likeMOV, FLV, AVI, WAV, MP3, MP4, MPEG, etc. are available with it.
on Apr 21, 2011 | Computers & Internet
I have a finepix s5500 camera but the softwear is xp and i need a vista version, is it possible.
All Fujifilm digital cameras will work on Windows Vista using drivers already installed on the operating system.
The finepix viewer software supplied with our cameras will require a update which can be downloaded from the following link
http://www.fujifilm.com/products/digital/download/02/index.html#windows5.3
Accessories
The following products are not compatible with Windows Vista:
FD-A1/FD-A2 (Floppy Disc Adapter)
DM-R1 (Image Memory Card Reader)
DPC-R1 (Image Memory Card Reader)
The following products are compatible with Windows Vista:
SM-R1/SM-R2 (Image Memory Card Reader)
PC-AD3 (PC Card Adapter)
DPC-AD (PC Card Adapter)
DPC-CF (CF Card Adapter)
DPC-UD (USB Pen Drive)
Oct 17, 2009 | Fuji Finepix Z20fd Digital Camera
Cannot download images
Use a separate card reader to download the pics.
Sep 24, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Eos 40d error 99
Error 99 can mean many things. Have you installed the latest firmware for the camera (version 1.1.1)? If you don't have, download it here (for equipment purchased in USA or Puerto Rico):
http://web.canon.jp/imaging/eosd/eos40d/eos40d-firmware-e.html
If you have the latest firmware, try this:
  1. Switch off the camera and remove the CF card and battery
  2. Keep the camera idle for 30 min
  3. Clean all the contacts of the camera (battery contacts, lens contacts etc) with an eraser. Do this keeping the camera facing down so that no debris fall into the camera.
  4. Attach the lens and insert the battery.
  5. Switch on the camera
  6. Insert the CF card
  7. If the error persists, format the card again
  8. If this does not work, try using another CF card.
Feb 06, 2009 | Canon EOS 40D Digital Camera
How to install Fuji Finepix 2650 in Windows VISTA environment?
Accessories
Nov 11, 2008 | Cameras
Nikon d100 cf card not recognized
yes i know about this problem. basically its your sensor reading chip which has burnt out. it can be replaced at a cost of about £40/ so not expensive.
[email protected]
bye
Oct 05, 2008 | Nikon D100 Digital Camera
Cannot transfer images from my Canon DSLR XTi to my computer
Having same issue as above - I thought it was my cable so I ordered a new one. The camera attempts to 'speak' to the pc - and then the Windows box pops up not recognising the USB installed device....I also uninstalled and reloaded the Canon software (had camera for 18 months and only started this rubbish a month back) - was about to re-laod my entire PC - thankfully I saw it was not only me.
Will send mine in for a Firmware update / service.
Mar 27, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Scandisk curropt
You'll need a CF reader/adaptor for your computer, and software such as this
http://www.softwarepatch.com/software/smartrecovery.html
Just type "recover CF card data" and you'll find a host of downloads.
Oct 18, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
70 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
