FLASHIN RED LIGHTS ON EPSON C86 PRINTER. RESET COUNTERS BUT STILL NOT WORKING .ERROR MESSAGE SAYS SERVICE REQUIRED -PARTS END OF NORMAL LIFE - COMMUNICATION ERROR ! CAN YOU ADVISE .THANKYOU , RAY HODGSON
THESE PRINTERS ARE CONSIDERED BIC LIGHTERS IN A TECH'S WORLD BUT YOU COULD TRY RE-SETTING IT AND OR REMOVING ALL SOFTWARE AND RE-INSTALL FROM SCRATCH.
From the information provided it sounds like you tried to reset the waste counter but didn't actually succeed.
The "Communication error" indicates you were probably using Windows Vista when you tried to use the resetter but failed to use Compatibility mode (set to WinXP SP2 mode + Run as administrator).
This article covers the sorts of errors you get when trying to use AdjProg service utilities and provides some solutions.
Further to that though, specific information on how to fit an external waste kit is also available for the C86 with the same guide being equally applicable to the C84 and C/D88 models as well.
Guide link
both red lights are flashing what should I do
replaced printer
Will reinstalling the computer software fix it if it seems to be a hardware issue?
