I'm using a Canon EOS digital rebel with a Tamron 18-200mm lense. Now i'm getting an Er 99 message when using it. An old canon 35-80 seems to work fine.
'Error 99' indicates some problem with
the AF contacts. This is a common error in Canon lenses. It could
indicate a very simple problem like dirty contacts or a much serious
one like the breakage of USM cable. As a first step, you can try
cleaning the lens and body contacts (the metal contacts between the
lens and body) using a pencil eraser. Be careful to hold the body
facing down so that no dust falls inside. After cleaning both the
lens and the body contacts, re-attach the lens and try shooting. If
the AF does not work still, you need to take the lens to an
authorized service center.
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
The message, "Err 99 Shooting is not
possible. Turn the power switch to<OFF> and <ON> again or
re-install the battery", appears on the camera's LCD monitor, and after
the above operation is carried out,the LCD monitor displays in a
language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following theseFixya Tips:
Follow this link to download a pdf version of the firmware installation instruction guide.
Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
I can help you fix the BUSY Error or Error 99 of your Canon EOS 1000D.
Installation of this Canon EOS 1000D firmware version 1.06 update will solve these problems:
You will get that error when using some lenses other than Canon. A lot of the older Sigma lenses have that issue. Do you get this error when using newer Canon EOS lenses?
You're probably right about the lens. Tamron lenses have a flexible circuit that drives the aperture blades. The aperture might need to be cleaned or the flex might be worn out. Either case needs a repair shop to correct.
