Contributor
- Posted on May 07, 2009
Re: My 32cc craftsman weed eater was running fine.when it...
Check for trash in the carb somtimes when you run then out of gas small peices of dirt or on older motors residue builds up in gas tank and it gets sucked into the carb there should be a screen that you can clean
about everything on thy ----- thing has been removed an cleaned, checked gap, its fine doubled checked the fuel ratio ok now what.
I have punped the ball 10 times, still nothing ,cleaned the screens, an have pulled to my arm is falling of.
Well, I didn't determine if you pushed the priming bulb a lot, but maybe it doesn't have one?
Have you poured a little gas into the carb to give it a jump start?
Did you press the priming bulb a dozen times to get the fuel flowing?
