Question about GE 25 in. PDW7380JSS Stainless Steel Built-in Dishwasher
Is this GE Profile dishwasher recalled?
What this GE Profile dishwasher Model # PDW7380J10SS and serial# 709166B recalled ever?
Posted by mfulk100 on
  • mfulk100 May 07, 2009
    Thanks so much! I was only copying what the service guy wrote down for me...guess he didn't look too closely!
  • Anonymous Apr 01, 2014
    I dont know how to clear the delay wash button. It wont clear
Carl Schulzetenberg
  • 1,543 Answers
No recalls on any GE Profile model dishwashers. (there may have been service bulletins, but no recalls) Also, you missed the first two letters of the serial number.
You can go to this web site http://www.geappliances.com/products/recall/ to find info on any GE recall.
Posted on May 07, 2009
Leaking around heating element posts that protrude through dishwasher body
Some dishwashers like your model number are under recall for a potential fire hazard due to water leaking through the heating element posts onto the wiring.
Your serial number must begin with the 2 letters listed . Below is the list of recall serial numbers: FL, GL, HL, LL, ML, VL, ZL, AM, DM, FM, GM, HM, LM, MM, RM, SM, TM, VM, ZM, AR, DR, FR, GR
Call the phone # below or check out GE recall website. What GE does is replace the element and gaskets, unless there is burnt or arcing visible on the wires, they may replace the dishwasher.
GE has determined that an electrical failure in the dishwasher's heating element can pose a fire hazard. GE will provide a free repair to all consumers with units affected by the recall. We ask that you not use your dishwasher until it is repaired and to disconnect the electric supply by shutting off the fuse or circuit breaker controlling it and inform all users of the dishwasher about the risk of fire.
Consumers who instead wish to replace their dishwasher with a new model can receive a rebate towards the purchase of certain new GE and Profile brand dishwashers. Consumers can use a rebate of $75 for the purchase of certain GE front-control plastic tub dishwashers, or a GE rebate of $100 for the purchase of certain GE front-control stainless tub dishwashers or GE Profile top control dishwashers. See the rebate form for eligible models.
GE is aware of 15 reports of dishwasher heating element failures, seven of which resulted in fire and smoke damage beyond the unit. No injuries have been reported.
The model and serial numbers are important, as not all dishwashers are included in the recall. Look at the inside on the front left side of the dishwasher tub to find the model and serial number.
This recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission, which will also monitor the effectiveness of the recall program.
Recall Hotline
866-918-8760
Monday through Friday, 8 a.m. - 5 p.m. ET.
Before calling, have the model and serial numbers on hand.
Customer Care
Apr 21, 2014 | General Electric Adora GHDA670N Built-in...
It won't turn on...the buttons won't even light up
Hi there is possibly a recall on this unit, if you give me full model and serial i can check for you to be certain, but if there is a recall you will want to turn the power off to this unit and call GE service for them to fix it and they can also fix your other problem, but its possibly related to the recall. Let me know.
Sean
Mar 30, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
My ge profile dishwasher oveheated.
There was a recall on some GE dishwashers, but yours was purchased a bit before those affected. Just to be sure, go to http://www.geappliances.com/products/recall/dw07/ and input your full model and serial number (including the last letter of the serial number). Of the models affected by the recall, I've personally seen (and have photos of) one that burned, plus one that was close to it. Recalled ones can be updated for free, or if you decide to replace, qualify for a rebate toward a new GE dishwasher. (the recalled ones had problems with the wiring inside the door) If your model is not one affected by the recall, I would contact GE customer relations via their answer center phone (800-626-2005) to report this potential safety issue.
Feb 01, 2009 | GE Profile PDW9880NSS Stainless Steel...
Dishwasher Non functioning
Disconnect power immediately! Several brands of dishwashers have had safety recalls over the past few years with bad switches or the rinse aid liquid leaking inside doors or inner insulation reacting with the wirering's insulation, in some cases causing fires. If you google dishwasher recall you will see GE, Maytag, Whirlpool/ Kenmore...... When you search or enter model numbers make sure you use complete model and serial numbers. If you leave off a letter or get one wrong the sites might tell you your model is not involved in the recall. I wish I was on my work computer now,... I'd include some photos of dishwashers which I serviced which did burn. Please leave a comment with your model and serial number.
Aug 31, 2008 | Dishwashers
We have a service contract with Broward Factory Service. My GE dishwaher went out with eater in it, no power. Checked the panel box flipped switch, nothing. The service tech. said the rinse aid cup leaked...
I was trying to find out if the dishwasher was on a recall list, and I did by calling GE direct. It was not, so the service I have is replacing the rinse aid box.
Thank you,
Aug 26, 2008 | GE Dishwashers
GE dishwasher Model # PDW7380J10SS serial #SL740885B the motor is making a really load clanking noise machine is only 15 months old
Model: PDW7380J210SS Ser: MH782183B
Dishwadhwasher stuck on Dry Clycle. How do I rest the system..
Jul 16, 2008 | GE Dishwashers
GE Profile Dishwasher beeping
Mine was doing the same thing. It was eligible for a recall.
Free repair or rebate toward new purchase. 1-877-275-6840 or go to website geappliances.com
Jul 01, 2008 | GE 24 in. Profile PDW9200J Built-in...
Concerning recall due to fire hazard. Kenmore model # 36315561790 serial # AT313271R
Go to the GE web site and look. If your model and serial # are listed they will send you a rebate form. This is good for up to $300 off a new dishwasher. If a fairly new model they will send a repair person to fix it for you at no charge. The fire hazare is caused by rinse agent leaking onto the wiring. If you have never used Jet dry or a similar product don't worry. It won't affect you. You can still get the dishwasher fixed free.
Jun 30, 2008 | GE Dishwashers
GE 25 in. PDW7380JSS Stainless Steel Built-in Dishwasher Logo
1,810 people viewed this question
Top GE Dishwashers Experts
Michael Thomas
Michael Thomas
Mike
Nathan Van Boven
Nathan Van Boven
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
