Motorola Mobility RAZR V3c Cellular Phone Logo
Posted on Oct 09, 2007
I entered the wrong code number
I was using some unlock software for a Razrv3c. It went we until I got to the part that said to enter the numbers to change the orginal phone code numbers. I hit the wrong number and told the phone to save to phone. I am not able to get the MPT V4 software to find the phone now. Can anyone help me with what to do to get back to the orginal numbers I messed up. Thanks, don [email protected]
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Oct 10, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
4596
Points
16
I know it sucks but try calling the service provider
8helpful
2answers
I need country code for nokia 6700 in pakistan
Steps
  1. Download software to generate the unlocking code. Software is available on some websites for free and some pay websites that also offer support if things go wrong. Find the Serial number of the cell phone, also known as your IMEI number. This can be done by either removing the back of your cell phone and looking underneath the battery, or simply by typing in *#06# into your cell phone. It should looking something like: 010082321439976
  2. Using the software you have downloaded, enter in your Manufacturer (which is in this case Nokia), your model number, and your IMEI number. Also enter your country and the Network. Calculate the code, this may be different depending on which software you are using. If your phone is the Nokia 3390 phone, select the model 3310, they are the same phone.
    You will get a series of codes that looks something like: #pw+555 979 507 5+1#. You will enter each of these codes until you find the one that works for you, it’s possible the first one won’t work.
  3. Remove the SIM card from your Nokia phone. This is typically done by removing the back cover of the phone and removing the battery and sliding the card out. Put the battery back in and power the phone on.
  4. You should see a message “Insert SIM Card”. Begin entering your generated code. Enter all of the characters you see in your code, including the # symbols. To get a ’p’ press * 3 times, to get a ’+’ press the * key 2 times, to get a ’w’ press the * key 4 times. Disregard any spaces in the code.
  5. Once you have finished entering a code that works you should see a message that says “SIM is not restricted” or “Restriction off” message depending on your model. If not, try entering another code. Be careful, entering a wrong code 5 times will mean that you will only be able to unlock the phone with a data cable.
Warnings
Attempting to unlock your phone is done at your own risk. Although unlocking your phone is legal, some cell phone operators might choose to void your warranty should you unlock your phone (then again, some cell phone operators won’t mind).
link: http://wiki.ehow.com/Unlock-Your-Nokia-Cell-Phone
2answers
Sch-u350 phone unlock code
enter wrong code for nearly 10 to 15 times...now call ur customer care and get the PUK number for ur number... after entering the wrong number it automatically asks u the PUK number...enter the number you got from the customer care...ur phone ll be unlocked......
Nokia 6288 unlock code
Warnings
2answers
UNLOCK 6288 FROM 3 AUSTRALIA
sorry i dont know the code for this model 6288 handset ....
1helpful
3answers
Security code
Hi, i can help you with a master code but you need to know something first.
1. if the wrong code has been entered more than 5 times then the phone is hard locked and can only be unlocked using flash lead and unlocking software.
so if you have not entered more than 5 wrong guesses then i can get a master code that resets the security code to what it was when new and it removes the security code untill you choose to use it again.
What you need to give me is your imei number this is found on back of phone under battery and looks like 123456/12/123456/1.
its 15 numbers long.
I need this code because every single phone has a set master code based on the imei number. i have the software to generate these codes as i worked for nokia for years so i can help you but let me know then i can assist you further ok.
2answers
My lock code wont work.
Hi, the problem is if you have entered the code wrong more than 5 times then the phone is hardlocked and will need unlocking software and lead ok.
Also is the code asked as soon as you switch the phone on if it is then i might be able to help you as every phone has a master code but this code wont work if its been entered wrong 5 times.
If you have not tried to enter any code more that 5 times then the master code should unlock your phone for you ok.
What i need is your imei number its on back of the phone under the battery and looks like 12345/12/123456/12 its 15 numbers long ok.
I need this as every single phone has a unique master code based on the imei number.
So as long as you have not tried entering more than 5 wrong guesses then the master code will work ok
May 05, 2008 • Nokia 7610
Lock code
SIM Pin Code.
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. ---
To reset this Pin number you need the:
Pin Unlock Code (PUK)
If you miss keyed (or forget) your SIM PIN code, and enter the wrong one 3-5 times in a row, the sim will lock up, and you'll need to enter the unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don't try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a "new" sim if the phone security code is entered.
To reset this Security number you need the:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security
Code wrongly too many times.
For IMEI 356404010441953 this is the Master Code:
3520316615 to use it:
You type in the security codes (any) until the phone request the Master code; when it does, leave your phone still, don't use it for 15 minutes, then type in the Master code.
2answers
Unlock personal security code for nokia 6288
Hi yes your right i can get you a master code for your phone but this code only works if the wrong code hasnt been entered wrong more than 5 times and it also only works if the phone is asking for the code when you switch it on.
If the wrong code has been entered wrong more than 5 times then you need to get a flash lead and unlocking software as the phone will be locked out from using over ride code ok.
Also if you have acess to your phone and you just need to change the code but can still use the phone then to change the code you need the lead and software.
If the phones locked and its asking for the code when you switch it on then the code i can give you resets the code and removes it untill you want to put a code back on the phone it resets it to what it was when new ok
What i need to get the code is your imei number its on back of phone under the battery and looks like 123456/12/1234567 its about 15 numbers long once i have this i can use the software that i have and generate your master code ok so let me know then i can help you ok speak soon
Security code
This code; 0530431 is the product code, it's mainly used to check the software version your phone is using. This is the version your phone should be on:
Latest available software for Nokia N70, product code 0530431
Version: 5.0638.3.0.1
Compare numbers
If this version is greater than your current software version, update now to get the latest features, applications and improvements. Go to Nokia Software Updater download To check the version that's on your phone now, type *#0000#
then compare with the one above.
1st Line is: Software Version,
2nd Line is: Software Release Date,
3rd Line : Compression Type. (
Nokia model type
SIM pin code:
If you simply can't switch your phone on because you have forgotten the PIN number, then
If you miss keyed (or forget) your SIM Pin code, and enter the wrong one 3-5 times in a row, the sim will lock up, and you'll need to enter the unlock code (PUK) to release it. You should ask your Service Provider for this code when you need it. Don't try to guess it, because after a few wrong guesses, the sim will be permanently disabled.
4helpful
3answers
Code problem
please use ufs 12 software for reset ur password
Top Motorola Mobility Cell Phones Experts
ADMIN Eric
ADMIN Eric
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
