Question about Epson Stylus DX6050 All-In-One InkJet Printer
Colour Ink Jet Cartridges emptying during a black ink print run
Something strange is happening with the printer. There are 4 inkjet cartridges. Black, Cyan, Magenta and Yellow. I rarely use colour so, Black ink is used up more quickly. Before I performed a mailshot of 50 letters, the Cyan and Magenta cartridges were nearly full. After the print run, the Cyan cartridge was empty and the Magenta cartridge was nearly empty. The letters did not include colours - Only black ink was required. Why has it happened and can I configure the printer to print black ink letters when one or more of the colour cartridges is empty?
Posted by paul_f_lloyd on
Graeme van Malsen
  • 519 Answers
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
Posted on May 07, 2009
The printer's lying to me
The printer requires both cartridges to have ink before the printer will initialize and operational. Even if you are only printing black and white both cartridge have to contain ink or the printer will error out. This is standard on all ink jet printers from every manufacturer. You will have to get ink before you can print.
Apr 28, 2013 | Canon Pixma MX410 All-In-One Printer
I have just replaced the black ink on my epson sx210 and it is not recognising it.The other cartridges are empty. Could this be the problem?
Taken fro the epson site where they describe how to print in black only
notes.gif Note:
You will not be able to obtain black ink only printing if any cartridges have run out. This is to ensure that air is not sucked into the print head (instead of the ink that prior to the cartridge running out was available) therefore potentially damaging the printer.
In order to function, the printer will require black and colour ink cartridges to be inserted with a certain amount of ink in each cartridge.
Jul 21, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Want to print only in black
search through your manual for grayscale options... this is usually code word for black and white...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 21, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printing B&W on a Pixma MP800 with empty color cartridges
no you cant print with emapty colour catridges you have to install the other full catridges.
Nov 23, 2009 | Canon Pixma MP800 All-In-One InkJet...
'empty' ink cartridges - green prints!
just fill up all the catridge bcoz in colour printer anyone of them is not fill up the printout not coming properly , after filling the catridge just check
May 26, 2009 | Epson Stylus R265 InkJet Photo Printer
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Can I use 4 black ink cartridges at the same time
No, the printer uses all cartridges for each print.
Jan 25, 2009 | Epson CX8400 All-In-One InkJet Printer
Printer not printing
Unfortunately, like most multi cartridge ink jet printers when one ink is empty the printer will cease printing regardless of whether you just want to print in black and white and you have plenty of black ink left. I have heard of people tricking the printer into believing the cartridge is full by placing coloured tape etc in front of the ink sensing device but I am not sure how the Brother senses the ink levels as i have some aftermarket ink cartridges for mine which seem to be completely non-opaque (unlike the originals). The need to have colour cartridges in even if you only ever print with black ink is good news for Brother as the MFC-210c uses a large amount of ink during it's routine cleaning cycles (that you cant stop) and will empty all 3 cartridges in under 6 months without ever printer a single drop of colour ink. Sorry about all the bad news, at least your not alone......
Dec 28, 2006 | Brother MFC 210C All-In-One InkJet Printer
Low black ink - can not print at all
Most epson inkjets that use separate colour and black cartridges will not print if either the colour or the black cartridge is empty. The printers come with cartridges when new but they are only part full and more ink is used up filling the printer reservoir when first starting up. Replace your black cartridge and you should be able to print. barrie60s
Jul 24, 2006 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus DX6050 All-In-One InkJet Printer Logo
767 people viewed this question
Top Epson Office Equipment & Supplies Experts
Thomas F. Schneider
Ekse
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
