I have a universal remote and a rca tv, i need the code or codes to program into the tv so i can use the universal remote on the tv..... thanks.
SOURCE: Codes to program an RCA remote control
my remote will only work the volume. i need to program the remote to use menu to adjust the picture.
SOURCE: lost my manual - need tv codes
Hi! The code of a GE Universal remote for a RCA TV are 0031, 0004, 0048, 0054, 0094, 0100, 0102, 0107, 0129, 0191, 0005, 0009, 0000, 0162, 0163, 0342, 0003 ,0015, 0022, 0096, 0113, 0125, 0179, 0187, 0188. In case none of these works for your TV you can try these steps for you to program your remote conrol.
1. Manually turn on the TV.
2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
3. Press and quickly release the desired TV button. The red indicator blinks off once.
4. Press the ON-OFF button repeatedly (up to 300 times) until the TV to be controlled turns off. The red indicator blinks off with each button press.
5. Press and release ENTER to install the code.
SOURCE: I need the remote control code for an old GE TV,
0704,012,0018,0002,0502,0006,0007,0601,0835,
0901,0114,0103,0803,0806,0310
