Question about Acer TravelMate 291LMi Notebook
Laptop 290 acer
Hi I have a acer laptop model no 290 travel mate.battery islaptop shwing a crtecul battry new but and no bakup time plz anser me
  • Anonymous May 11, 2010
    Generally, the life of the battery is less than a year if used continously. This the reason why they dont give warranty on Laptop battery.
    Can you please tell, how old is that battery?
    How do you use it? Charge and then use on battery? or Work while charging? .
    Please answer these questions, so that i can help you.
    Thanks and Regards,
    Techno-Geek.
Do all the Acer Travelmate 240 series laptops use the same rechargable battery
This high capacity rechargeable Acre Travel Mate 240 replacement battery definitely disposes of more power than the battery which was included in the delivery of your device.This laptop battery for Travel Mate 240 is 100% compatible and will meet or exceeds original specification.Made with premium quality cells,the Ac er laptop battery for Travel Mate 240 has been tested for safety and designed for high performance
Dec 24, 2012 | Acer TravelMate 244XC Notebook
Should i use my new acer 5760 on mains power when possible
It depends upon how much time you run your laptop on battery power, you can keep an eye on the battery charge level when you connect it to mains power. You do not need to keep it on mains power all the time, only when the battery level drops to a low level and needs charging.
The laptop will warn you when it is low on battery power.
Aug 29, 2011 | Acer Travel Mate 7720G-932G50MN Notebook
Forgot the password , how to open my notebook ? acer-travel mate 2490
i have sulation if u hhave bios programer i have bios this model if u no have u 3 time inter inter inter system give the code plz send me coad i give u master password
thanks
Feb 19, 2011 | Acer TravelMate 4230 Notebook
Hi, I can not use a microphone in my Acer Travel mate 290, It has already reinstalled the XP home edition. I have tried to use a microphone through the mini jack and with USB, and in either case doesn't...
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
don
Feb 18, 2011 | Acer TravelMate 290 Notebook
Break bios password in acer 2420 travelmate laptop
remove the cover which has your power button and covers the LCD cables. Remove the keyboard and flip it over, being careful to not pull too hard on the cable. There's 2 small triangular silver connection pads beside the keyboard connector on the main board - connect them together and power on your computer (flat screwdriver works fine). Press the f2 key - you'll find it doesn't prompt you for a password. You can lift off the connections now. Go to exit and save changes, and you're password free.
. . <-connect these
. . . __________________
. . . __________________ <-keyboard connector
Apr 05, 2009 | Acer Computers & Internet
Want to upgrade my hard drive
Any latop/notebook hard drive wil fit.
Jan 16, 2009 | Acer TravelMate 244LC Notebook
Acer /travel mate 260
check partmaster.co.uk, they have laptop keyboards for my acer
approx £25
May 24, 2008 | Acer NSK8458AN Keyboard
Set up password
go to the control panel and go on to password then choose which password you want and put that in all problem solved
Jan 05, 2008 | Acer TravelMate 290LCi Notebook
No sound acer travel mate 290
hi! have you try to system restore? or update windows?
Nov 30, 2007 | Acer TravelMate 290 Notebook
Acer TravelMate 291LMi Notebook Logo
77 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
