Question about Dell 962 Photo All-In-One InkJet Printer
My printer is on pause printing , how to get it off this option
My printer just quit printing, went to control panel, then hardware and sound, then to printers. the printer book on the 926 printer said to .make sure pause printing is not selected ,mine is on pause printing and I can't seem to clear the pause away. your suppose to be able to right click and clear that option, I just can't get the option cleared. I was able to delete the built up printing jobs, just can't get rid of pause.
Posted by Judy Simmons on
  • Anonymous May 24, 2009
    how do i get my printer off pause
Anonymous
If you can't get it off "pause", then re-install software.
Posted on May 17, 2009
How can I unpause my printer?
Locate the printer you are using like this by clicking on "Start" - "Control Panel" - "Hardware and Sounds" - "Printers". Right click on the printer in question and select "Resume Printing" since it was paused before. Good luck.
Jun 30, 2012 | HP Photosmart C4680 Q8418A InkJet MFC /...
My dell p703w printer is not printing black even though i cleaned printer head and reset setting tried several new cartridges what do i do now
Printer Problems Ensure that the printer power cable is firmly connected to the printer and the electrical outlet.
Determine if the printer has been held or paused.
  1. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
In Windows Vista®:
  1. Click windoa14.jpg ® Control Panel.
  2. Click Hardware and Sound.
  3. Click Printers.
  1. Right-click the printer icon.
  2. Ensure that Pause Printing is not selected. If Pause Printing is selected, click Resume Printing.
Ensure that you installed the ink cartridges correctly and removed the orange caps from each cartridge.
For more information, see Replacing Ink Cartridges.
Ensure that you loaded the paper correctly.
For more information, see Loading Paper.
Ensure that the printer is not connected to a PictBridge-enabled camera.
For more information, see Printing Photos From a PictBridge-Enabled Camera.
for more detail see this page
http://support.dell.com/support/edocs/systems/p703w/en/UG/troubles.htm
i hope this helpful
thank you for using fixya
Feb 08, 2011 | Dell P703w Printer
How do i print black and white?
Hi!
Kindly follow these steps:
1.
  • On Windows XP or earlier: Go to Control Panel -> Printers and Faxes
  • On Windows Vista/7: Go to Control Panel -> Hardware and Sounds -> Printers (or Control Panel -> Printers - if on classic view)
2. Right click your Pixma printer icon and choose Printing Preferences.
3. In the dialogue box, tick the Grayscale Printing option.
4. Click OK to save and close.
Print a test page to see if you succeed...
Repeat and un-tick that option if you ever want to revert to color printing again.
Hope I helped,
Pelu.
Mar 17, 2010 | Canon PIXMA MP470 All-in-One Printer
I cannot print, the service spooler is not running
In run window type services.msc and the go to print spooler option just stop and restart the service.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | HP LaserJet 1022 Printer
My hp printer is stuck on pause. I need free help to get it off of pause. Thank you. I tried run and tried to create a notebook but that did not really work out very well. Or else I didn't do it very well....
I went to Control Panel, then Hardware and Sound, then Printers, then double clicked on the word "Paused" under my printer's status and clicked "Resume Printing" -which worked for me when my HP printer was stuck.
Oct 13, 2009 | HP Compaq dc5700 Microtower - Free Flat...
Printer always says its offline even though its on and connected
If you are Windows XP Operating System, perform the steps below:
1. Click Start --> Printers and Fax.
2. Right click the printer icon and check the following:
a. Check whether the All-in-One is set as default printer.
b. Ensure that the there is a check mark on the "Use printer online". If you have the Use printer offline, make it online by selecting the option.
c. Ensure that there is no check mark on the Pause printing.
Check for the default printer and USe printer Online in the printers and faxes folder.
Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
Sep 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
MacBook Pro will not recognize drivers for OKI C3200N
Sir,
Go to (Start > Control Panel > Hardware and Sound > Add a device) Check for connected devices. You can also go to (Start > Control Panel > Hardware and Sound > Add Printer > Local) check the USB1, 2, 3 options is available for using an existing port. The options are LPT1, 2, 3 (Printer Port) | COM1, 2, 3, 4 (Serial Port) | FILE (Print to File) | TPVM (Thin Print) | XPSPort. Select the appropriate port and try it…..
Thanks
good luck
Aug 07, 2009 | OKI C3200n Led Printer
IT SAYS ITS OFFLINE, I NEED IT ONLINE.
perform the syeps below if you are using XP Operating SystemL
Step 1:
Determine if the printer is paused or offline :
1.Open the printers folder, if necessary.
a.Click the Start icon.
b.Click Control Panel.
c.Click Hardware & Sounds.
NOTE: This step is not required when using Classic view in Windows Vista.
d.Click Printers.
2.Right-click the name of the printer and then click Open.
3.Click Printer.
4.Verify that Pause Printing and Use Printer Offline are not selected.
5.Press Esc to close the window without making any changes.
Step 2:
Apr 06, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Frequently changes its status to offline; have wireless connection
please perform the steps below:
Step 1:
d.Click Printers.
3.Click Printer.
Step 2:
Aug 12, 2008 | HP Photosmart C7180 All-In-One InkJet...
My printer says it is offline and now it wont print
perform the steps below if the Operating System is XP
Step 1:
d.Click Printers.
3.Click Printer.
Step 2:
Nov 28, 2007 | HP DeskJet 340 InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
3,674 people viewed this question
Top Dell Office Equipment & Supplies Experts
Richard C Cohen
Richard C Cohen
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
