Question about Kohler BALLAD 25X22 Stainless Steel Kitchen Sink - 1-HOLE K-3258-1-NA
I have many scratches on my kohler stainless sink.how do I remove them?
Posted by psg5 on
Anonymous
    President:
  • 1,489 Answers
You would use rubbing compound -- same kind of stuff as used on autos -- there are different grits -- super fine on up, just like sandpaper. It'll tak a lot of rubbing. Probably good do a reasonable job with a buffer/etc. on a drill motor.
Posted on May 07, 2009
How to take care of stainless steel sinks?
Here I show you how to care stainless steel sinks:
  • Clean stainless steel at least once a week.
  • Always apply stainless steel cleaner/polish with a nonabrasive cloth or sponge, working with, not across, the grain.
  • Do not use steel wool, wire brushes or abrasive sponge pads. Use only non-scratch cleaning pads.
  • Cleaners containing chloride (bleach) are not recommended. If used, rinse the surface immediately to prevent corrosion.
  • Most stainless steel products will scratch from everyday use. However, these scratches will blend over time to create a unique finish.
  • Do not store open containers of cleaners or chemicals such as acids, bleach, sodium chloride, lye, toilet bowl cleaner, drain cleaner, or hard water stain removal products under your sink.
Cleaning directions listed pertain only to their corresponding material and don't seem to be meant for regulator cleansing. regulator cleansing directions for chrome and vitreous china.
Success with cleaners and procedures depends upon such factors because the hardness and temperature of the water, using exact measurements of ingredients, changes in cleaning formulas and therefore the condition of the merchandise being clean. Since there are variations at intervals these factors, Kohler cannot guarantee the effectiveness of the formulas mentioned.
Allowing water to evaporate on metal will form water deposits. To avoid this and keep your product looking beautiful, it is important to wipe the sink clean with a soft cloth after each use.
Apr 05, 2018 | Home
How do you take care of stainless steel sinks?
Here i show you how to care stainless steel sinks:
Cleaning directions listed pertain only to their corresponding material, and don't seem to be meant for regulator cleansing. regulator cleansing directions for chrome and vitreous china.
Apr 03, 2018 | Home
Black Kohler sink has scratches from washing my pots and pans. It is only 2 weeks old...how do I remove them?
Try getting a light rubbing compound and buff it out . Hopefully, you have scratched it too deep. I know this hurts when you scratched. No one likes to see there "new" sink messed up.
Nov 04, 2012 | Kohler Nice Cast Iron Kitchen Sink
How can I remove scratches on a stainless steel sink please
if the scratches are very small, you can mix up a paste made from baking soda and vinegar,, clean with a soft cloth and rinse
Aug 29, 2011 | Moen 22218 Camelot Self-Rimming Double...
Rubber feet on stainless steel sink basket are falling apart
Kohler is generally good about standing behind their products. I would get a hold of customer support and they should help you with that.
Nov 27, 2010 | Kohler K-8803-VS Duostrainer sink basket...
How to maintain cleaning and scratch free black sink,my sink has spots and scratches on it. how to avoid these problem
Using soft scrub or some brand similar is the best thing to use. Manufacturers reccomend only soap and water, but soft scrub is best. Be sure to never use abrasives on any fixture, it will scratch and void warranty
Kohler makes a cleaning agent for cast iron sinks, if this is what you have.
hope this helps
Apr 14, 2009 | Kohler K-5988-2-7 Entree Self-Rimming...
Plastic coated sink protectors - rubber feet deteriorated
You can get a product called Plasti-Dip at your hardware store. It is the stuff used to plastc coat tools.
Mar 09, 2009 | Kohler K-8803-VS Duostrainer sink basket...
Stainless Steel Sink Question
s with most things, your stainless steel sink WILL scratch with use. However, over time as the sink ages, scratches will become less apparent and in fact blend into the surface. Minor scratches on the inside surfaces of the bowl may be blended into the sink by lightly rubbing a Scotchbrite pad in the direction of the finish grain. Be sure to rinse thoroughly with water and towel dry after this procedure, removing any particles left over from the Scotchbrite as you rinse.
Aug 27, 2008 | Advance Tabco Stainless 3 Compartment...
Kohler BALLAD 25X22 Stainless Steel Kitchen Sink - 1-HOLE K-3258-1-NA Logo
163 people viewed this question
Top Kohler Plumbing Experts
Mike
Bill Johnson
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
