Question about Bravetti EP4305FS Deep Fryer
On/off switch is not able to hold it's position. No up or down position.
Posted by oggie150 on
  • oggie150 May 08, 2009
    Obviously!
Anonymous
    Problem Solver:
  • 4 Answers
Replace switch
Posted on May 07, 2009
Why does the power window button blink on and off and the automatic feature doesn't work in the 2008 Toyota Sienna?
NOTE:
Anytime the batteryterminal has been disconnected, please initialize the driver's door power windowand front passenger's door power windowafter reconnecting the batteryterminal.
With ignition switchin the "ON" position, do the following:
1. Push down and hold the driver's door power windowswitch to completely open the window.
2. Pull and hold up the driver's door power windowswitch until the window closes.
Continue holding the switch for approximately one second until the switch changes from blinking to a constant illumination.
3. Check for proper operation of the "one-touch open and close" function by fully pushing the switch briefly to the "DOWN" and "UP" positions.
At this time the power window switchfor the passenger's door windowshould be blinking.
4. Push down and hold the passenger's door power windowswitch to completely open the window.
5. Pull and hold up the passenger's door power windowswitch until the window closes.
6. Check for proper operation of the "one-touch open and close" function by fully pushing the switch briefly to the "DOWN" and "UP" positions.
Feb 09, 2016 | Toyota Cars & Trucks
Program key fob
  1. Close all vehicle doors.
  2. Insert the key into the ignition.
  3. Hold down the power UNLOCK button on the driver's door panel-continue to hold down until instructed to release in step 9.
  4. Perform steps 5 through 8 in fairly rapid succession.
  5. Turn the ignition switch to the ON position (as far as you can go without starting the engine).
  6. Turn the ignition switch to the OFF position.
  7. Turn the ignition switch to the ON position.
  8. Turn the ignition switch to the OFF position.
  9. Release the power unlock button on the door panel. The vehicle will lock and unlock the doors automatically.
  10. Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until the door locks and unlocks. This step may take up to 30 seconds.
  11. Repeat step 10 NOW for each additional transmitter (including any existing transmitters).
  12. Turn the ignition switch to the ON position in order to exit the transmitter programming mode.
Mar 12, 2015 | 2002 Chevrolet Chevrolet Tahoe
How do i do a hard reset on a magellen maestro 4040?
  • 1 Slide the Magellan GPS unit's powericon1.png switch to the off position, if your GPS has a two-way slide-style switch. Hold the switch in the off position for 8 seconds or more to reset the device.
  • 2 Slide the switch to the reset position if your GPS has a three-way switch. These switches feature "Reset," "Off" and "On" labels. Hold the switch on the reset position for 10 seconds to initiate a reset.
  • 3 Inspect your GPS for a reset pin hole if the unit has a push-down power button rather than a switch -- check the bottom and sides of the device for a pin-sized hole. Insert a pin or a straightened paperclip into the hole, pushing until you feel a slight pop. Hold the pin or clip down for 10 seconds and the GPS will reset.
  • Read more: http://www.ehow.com/how_5635240_reset-magellan-gps.html#ixzz33LpAdUJE
    Jun 01, 2014 | GPS
    2010 toyota venza side window hasa been replaced and when it goes up to top it goes back down because it thinks ther is something in the way!
    Try this
    turn the key to the run position, do not try and start. press and hold the window switch in the down position until the window is all the way down, then count to three. Hold the window switch in the up position until the window is all the way up, then count to three. Push the window button down to engage the auto down function (you do not need to hold it down). once the window is all the way down pull up on the window switch momentarily to activate the auto up (you do not need to hold the switch in the up position). The window should now be reset.
    I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
    Nov 29, 2012 | 2010 Toyota Venza
    How do i program a keyless remote for a chevy 2002 S10?
    3. Hold down the power UNLOCK button on the driver’s door panel-continue to hold
    engine).
    transmitters).
    mode.
    Mar 05, 2010 | 2002 Chevrolet S-10
    Battery went dead in 2007 Chevy Silverado truck. Now, remote does not work. Replaced battery in remote and it still does not work.
    Make sure you have one working ignition key and all remotes for the vehicle.
    1) Close all vehicle doors.
    2) Insert the key into the ignition.
    3) Hold down the power UNLOCK button on the driver’s door panel-continue to hold down until instructed to release in step 9.
    4) Perform steps 5 through 8 in fairly rapid succession.
    5) Turn the ignition switch to the ON position (as far as you can go without starting the engine).
    6) Turn the ignition switch to the OFF position.
    7) Turn the ignition switch to the ON position.
    8) Turn the ignition switch to the OFF position.
    9) Release the power unlock button on the door panel. The vehicle will lock and unlock the doors automatically.
    10) Hold down the LOCK and UNLOCK buttons on the transmitter simultaneously until the door locks and unlocks. This step may take up to 30 seconds.
    11) Repeat step 10 NOW for each additional transmitter (including any existing transmitters).
    12) Turn the ignition switch OFF then to the ON position in order to exit the transmitter programming mode.
    Feb 28, 2010 | 2007 Chevrolet Silverado 1500 2WD
    Is it possible to reprogram a keyless entry remote to a 1998 GMC Jimmy?
    1998 and newer Jimmy's and Blazer's
    engine).
    transmitters).
    mode.
    Good luck and keep me posted, the 1997 was dome different.
    Jan 23, 2010 | 1998 GMC Jimmy
    Lost working keys extra will unlock but does not start how do i program extra key to start car
    On 2002 model try the following:
    engine).
    transmitters).
    mode.
    from ProgramyourRemote
    Jul 04, 2009 | 2002 Chevrolet Tahoe
    Program a new key fob for a 2002 chevy tahoe
    engine).
    transmitters).
    mode.
    Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
    May 27, 2009 | 2001 Chevrolet Blazer
    Need the procedure to program my new remote...THANKS!!!
    engine).
    transmitters).
    mode.
    May 20, 2009 | 2005 Chevrolet Silverado
    Bravetti EP4305FS Deep Fryer Logo
    Top Bravetti Kitchen Appliances - Others Experts
    Mike
    ADMIN Canada
    ADMIN Canada
    ray gallant
    Are you a Bravetti Kitchen Appliances - Other Expert? Answer questions, earn points and help others
