Canon PIXMA iP3000 InkJet Photo Printer Logo
Posted on Oct 09, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CANNON PIXMA IP1300 INK CARTAGE PROBLEM
MY PRINTER STOPSUDDENLY DUE TO CUT OF LIGHT WHEN IT WORKING WHEN I STRAT AGAIN AND GIVE PRINT COMMAND A MESSAGE COME {INK HAS RUN OUT } AND PRINTER DOES NOT PRINT
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Mar 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
2697
Points
14
Hey i've got same problem as you are.... what i did was just simply remove the cartridge and tried to print some docs without the cartridge and it should say that the cartridge is not recognize.... repeat the operation thrice and then put the cartridge back..... this one worked for me.... this might also help you.....,,,
Anonymous
Level 2:
Guru:
  • Expert 377 Answers
  • Posted on Mar 15, 2008
Anonymous
Expert
Level 2:
Guru:
Answers
377
Questions
Helped
340437
Points
842
Dera vicky
many problem that canon has give to us, but let me to try to give some advice for you
the trick is
Waste Ink Counter Reset. Manual for Service mode
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.)
should be orange.
5. Press and release the RESUME button again, the indicator
6. Release both buttons
and for the tool program i send you'll later after i receive your e-mail
just send me your email
oke
but i hope the trick can solve your problem
cropp
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 11, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
302
Points
0
RUNNING TEST PRINTER COLORS PRINT...CLEANED INK JETS...PRINTS PART OF PAGE ONLY...ARE DRIVERS FOR VISTA AVAILABLE??? DOES NOT HAVE VISTA IN BOOK.
THANX
Hi, I am using a Canon Pixma iP1300. I am getting service error 5100.
Canon printer error 5100 has shown due to paper jam, improperly seated ink tank and more. Follow the simple steps to fix canon printer error 5100:
·Reset the ink cartridge
·Clear the paper jammed
·Reset the printer
Read more
Canon printer error codes and their solutions.
Canon pixma ip1300 showing ink is running low
i think you must searching "kontol" at google
My cannon 250 inkjet printer is not able to print. It gives the message that "your cartage is not insert properly even I was try my best to insert it" what is the problme?
If you have taken the cartirdge while the set was On it might have changed the settings or a communication error would have crept into the PC . In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.
Yellow color not coming in my canon pixma IP 1300 printer after first refill.
I had this problem, and it was due to a ruined print head, you can buy these at any local electronics store. Also while you are buying the print head buy another color cartage, and try that before your replace the print head.
Will not scan due to no colour ink. do not want to
hi,
As you dont want to use the colour ink,When you give the print command you wil get the print properties page ,In that you can select black and white so that you wil not use up the colour catridge. It uses black catridge only.
thanx
Won't print color. Color inks are full, cleaned jets, but still won't print in color.Black ink prints.
Due to not used your cartage the opening of the cartage lid become freeze so put it for some time below running water and then try to print it will work
2answers
Price of catridge of cannon ip1300
these are the cartridges used in 1300
CL-41 FINE Colour Cartridge
PG-40 FINE Black Cartridge
click here for cl 41 prices
http://www.google.com/products?q=cl-41
Click here for pg-40 prices
http://www.google.com/products?q=pg-40
Let me know if you need anything else.
Thanks,
Ekse
5helpful
4answers
old marine
old marine
ZJ Limited
ZJ Limited
