Question about Whirlpool Duet GHW9150P Front Load Washer
Washer won't turn on, code FdL appears in timer window, GHW9250M
1] I press control on
2] press hold to start
3] I here several soft clicks
4] then a code appears in the timer window
5] F dL
6] it does not start
Posted by duediligence on
Michael Masters
  • 6,784 Answers
Hi. this is a Door lock mechanism error. here is a description of the code and troubleshooting tips below.
Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
You may need to replace the door lock mechanism if the wire harness checks out OK. Now, if the wires are connected well and the door lock mechanism if working, this could be a more serious issue concerning the Control board.
You can test the door lock mech by using a volt neelde or multimeter as well. use the connector clips for testing the proer voltage.
Please rate and god bless:)
Posted on May 06, 2009
How do I reset a hp LaserJet 3055
Soft reset:
1. Press Menu. 2. Simultaneously press and then release the * button and the # button to open the developer's menu. 3. Press the < or > button until the message REINIT FFS appears on the second line of the control panel display. 4. Press . 5. The process takes approximately 2.5 minutes. During that time, the control-panel display will change several times before returning to Ready. 6. When the Ready message appears on the control-panel display, press Cancel to exit the developer's menu.
NVRAM reset:
1. Turn off the all-in-one. 2. Press and hold down the * and 5 buttons. 3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout the entire power-on sequence. 4. When Permanent Storage Init. appears on the control-panel display, release the buttons. 5. When prompted, set the language and telecom country/region. 6. Allow the all-in-one to return to Ready before using it.
Best of luck..
Oct 12, 2014 | HP LaserJet Office Equipment & Supplies
My optiplex 320 is making two high pitched beeps on starting boot, also im not getting anything on the monitor
James,
It sounds like the refresh rate is set to high. Since you do not mention what OS is installed I have listed information on how to change in Windows,XP.
Start the computer and press the F8 key. Choose Safe Mode. Once the system gets into Windows follow the steps below and then restart the computer. If this does not resolve your issue email me at my email address below and include your OS information.
How to Change the Screen Refresh Rate of Your Monitor
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
NOTE:
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Or your system is giving off a beep code in which case the beeps come in a 3 beep sequence. Below is the beep codes and what each represents.Beep Codes
Troubleshooting steps and more information about the OptiPlex 320 beep codes Beep Codes Code Cause 1-1-2 Microprocessor register failure 1-1-3 NVRAM 1-1-4 ROM BIOS checksum failure 1-2-1 Programmable interval timer 1-2-2 DMA initialization failure 1-2-3 DMA page register read/write failure 1-3-1 through 2-4-4 DIMMs not being properly identified or used 3-1-1 Slave DMA register failure 3-1-2 Master DMA register failure 3-1-3 Master interrupt mask register failure 3-1-4 Slave interrupt mask register failure 3-2-2 Interrupt vector loading failure 3-2-4 Keyboard Controller Test failure 3-3-1 NVRAM power loss 3-3-2 NVRAM configuration 3-3-4 Video Memory Test failure 3-4-1 Screen initialization failure 3-4-2 Screen retrace failure 3-4-3 Search for video ROM failure 4-2-1 No time tick 4-2-2 Shutdown failure 4-2-3 Gate A20 failure 4-2-4 Unexpected interrupt in protected mode 4-3-1 Memory failure above address 0FFFFh 4-3-3 Timer-chip counter 2 failure 4-3-4 Time-of-day clock stopped 4-4-1 Serial or parallel port test failure 4-4-2 Failure to decompress code to shadowed memory 4-4-3 Math coprocessor test failure 4-4-4 Cache test failure
Thank You,
Dell-Jesse L
Dell Social Media and Communities
email [email protected]
Sep 18, 2013 | Dell Computers & Internet
Have Error Code E20 - won't drain. How do I approach?
The diagnostic test is used to check individual component function only. TO START THE TEST: • Turn the Program Knob to the start position, Spin Only. • Press Start/Pause to start the cycle and save it. • Press Cancel to stop the cycle and turn off the LEDs. • Press Cancel again to turn on the LEDs. • Within 5 seconds, press and hold the Options and Start/Pause buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened.When the door is opened, the drum light should turn on. 6. Turn the program knob (5) clicks from the start position. The washer will fill and tumble. Once tumbling has started, the Boost Heater (if so equipped) will turn on. 7. Turn the program knob (6) clicks from the start position. The drain pump & door lock solenoid will activate and the washer will operate in high spin. 8. Turn the program knob (7) clicks from the start position. The control will signal the last error code. Exiting Diagnostic Mode There are two options for exiting theDiagnosticTestmode and returning the washer to normal operation: a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR b) Turn the program knob clockwise 2 or 3 clicks after the start position. Press Options and Start/Pause buttons together for a few seconds until wash cycle LEDs appear.
Dec 26, 2010 | Frigidaire Affinity ATF7000E Front Load...
Gps module not responding
Hello :
I recommend you to reset your device .
Try this for soft reset :
1. Turn unit OFF
2. Press and hold the PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map appears
If soft resetting didn't work , then I would recommend you with hard resetting . Here is how to hard reset your device . But Hard Reset (Deletes stored GPS Data such as Waypoints and trails) .
1. Turn unit OFF
2. Press and hold the ZIN&ZOUT Keys at the same time
PLEASE DON'T FORGET TO RATE !
Apr 16, 2010 | Lowrance LCX-25c GPS Receiver
Whirlpool won't turn on code F dl appears
The problem is your door latch. You either have a latch that is defective, or the interconnecting wiring harness needs to be checked to ensure it is making good contact. The following link explains how to disassemble the washer and/or replace the latch:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Read through the link and let me know if you have any questions. A replacement latch can be purchased on line at searspartsdirect.com, appliancepartspros.com, pcappliancerepair.com, or repairclinic.com. I've used all these web sources with great results. All offer competitive pricing, so shop all of them for the best price. I hope this helps you.
May 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet says Fdl washer wont turn on
F/dL ERROR IS FOR :-- Door Lock ErrorA Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
TO RESOLVE THE PROBLEM :---
Door Lock Mechanism broken or removed from the Door globul1a.gif Check Door Lock/Switch Assembly globul1a.gif Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) globul1a.gif Door Lock/Switch Assembly Failure
May 06, 2009 | Whirlpool GHW9400SU Front Load Stacked...
Motor control board frigidaire
E59 No tacho signal for 3 seconds in other words sounds like a bad motor
Diagnostic Test:
The diagnostic test is performed by using the Program Knob. To START THE TEST:
? On non-digital display models, turn the Program Knob to start position, Drain/Spin.
? On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that can be rotated 360?, turn the Program Knob to start position, Drain/Spin.
? Press Pause Cancel to turn off LEDs.
? Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons.
5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate.
6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened.
7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble.
8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test).
9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating.
10. Turn the program knob (9) clicks from the start position. The control will signal the last error code.
There are two options for exiting the Diagnostic Test mode and returning the washer to normal operation:
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Pause Cancel buttons together for a few seconds until wash cycle LEDs appear. If a situation arises where you cannot exit the Diagnostic mode as described above and the bank of 5 LED?s on the right end remain ON regardless of Program Knob position, a combination of pushed buttons may have caused the control to enter a special factory test mode. Disconnect power to reset the control to return washer to normal operation is this occurs.
To clear latest stored error code:
Place the control into Diagnostic test Mode.
? Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
? Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
? Exit Diagnostic Mode to return the washer to normal operation.
Dec 30, 2008 | Frigidaire ATF6000ES Front Load Washer
How do I run a diagnostic on a Fridgidaire
Diagnostic Test: The diagnostic test is performed by using the Program Knob. To START THE TEST: • On non-digital display models, turn the Program Knob to start position, Drain/Spin. • On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that can be rotated 360°, turn the Program Knob to start position, Drain/Spin. • Press Pause Cancel to turn off LEDs. • Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate. 6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened. 7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble. 8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test). 9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating. 10. Turn the program knob (9) clicks from the start position. The control will signal the last error code. Exiting Diagnostic Mode There are two options for exiting the Diagnostic Test mode and returning the washer to normal operation: a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Pause Cancel buttons together for a few seconds until wash cycle LEDs appear. If a situation arises where you cannot exit the Diagnostic mode as described above and the bank of 5 LED’s on the right end remain ON regardless of Program Knob position, a combination of pushed buttons may have caused the control to enter a special factory test mode. Disconnect power to reset the control to return washer to normal operation is this occurs. To clear latest stored error code: Place the control into Diagnostic test Mode. • Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code. • Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared. • Exit Diagnostic Mode to return th e w a s h e r t o n o r m a l o p e r a t i o n .
Dec 24, 2008 | Frigidaire ATF6000ES Front Load Washer
Sonar Problem
Try a soft reset first, if that doesn't correct it try a hard reset. BE SURE and Save Data before th eHard Reset, it clears all waypoints and such.
Soft Reset Hard Reset
LCX 15mt Reset 1. Turn unit OFF 1. Turn unit OFF 2. Press and hold the PAGES key 2. Press and hold the ZIN&ZOUT Keys at the same time 3. Press and hold the PWR key 3. Press and hold the PWR key 4. Release both buttons when the USA map appears 4. Release both buttons when the USA map appears
Jun 26, 2007 | Lowrance LC X-15MT Sonar
Whirlpool Duet GHW9150P Front Load Washer Logo
230 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
