Question about Pentax Photography
35mm manual SLR keeps taking photos even though it must be the end of the film?
Posted by tashabooth_6 on
Anonymous
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 216 Answers
You probably didn't get the film leader caught by the takeup spool - they might be no pictures taken at all. Go into a dark room and open the back, you can feel if the film is loaded.
Posted on May 07, 2009
How do I reload new film
Open the camera back.
Put the cassette in the film chamber.
Pull out the end of the film leader, and take it over to the take-up spool.
Thread it onto the take-up spool as per the instructions in the manual.
Close the camera back.
Wind on until the counter shows '1'
Take your photos.
Jan 01, 2017 • Photography
What type of film does a n60 slr camera use
The N60 uses standard 35mm film (also known as 135). 35mm film usually comes in 12, 24, or 36 exposure rolls, any of which will work. 35mm film is available in black-and-white, color transparency (color slides), and color negative (color prints). It's also available in infrared, both color and black-and-white, but the N60 will not work with infrared film.
35mm film is available online and at any camera shop. Many department stores, drugstores, and even supermarkets also carry film, though not as wide a selection as a decent camera shop.
I just bought a Minolta maxxum QTsi from a lady and it had no manual with it, I can't figure out how to load the film. Can you take me step by step on how to load the film and how the camera works when...
Hi, I've found the instruction manual online for you, http://www.mediacollege.com/equipment/manual/konica-minolta/camera/maxxum-qtsi.pdf that way you have it for future reference. For loading film you open up the back of the camera and make sure that the end of the roll of film is aligned with a red mark and then you close the back. For taking pictures you press the shutter button half way in order for it to focus, when the image you want is framed you press the shutter button the entire way and it'll take the photo.
I have a Canon AE-1 SLR camera for my high school photo class and it was working fine but all of a sudden my film advance lever locked and now it wont take any pictures, does anyone know how to fix this?
This may not be the problem, but could it be that you've run out of film. The end of the film is attached to the 35mm film canister. When you run out of film it will prevent the advance level from moving.
1helpful
I need to convert my manual lens to a digital body. what digital
If you have Ricoh lenses that do not have electrical contacts, you can use the lenses on Pentax digital SLR cameras.
If you have Ricoh lenses with electrical contacts, you can not use them on Pentax digital cameras.
I finished taking pictures but it didnt rewind. did i load the film wrong? or did the batteries die? or whats up
Have you tried taking just one more pic to see if that triggers the rewind? If that didn't work, most film cameras have a rewind button. Usually on the bottom of camera. If you still can't get your film to rewind, take camera to your nearest photo finisher. They should have a dark box; they can remove your film manually.
I was taking some photos (I had got around taking 4 exposures) and all of a sudden (and this is the first time its ever happened) I was not able to take anymore pictures. It sounds like the Shutter Release...
it seems to think you reached the end of the film. Try rewinding. Once in a great while film does not want to exit the canister for whatever reason. It stops. that creates tension, film advance motor stresses out and signals the computer program which tells you that it thinks you're outa film. REWIND!!!
I doubt you did anything wrong. Try rewinding the film. Another possible fix if its electronic issues is to remove power(battery) and reinstall battery.
lightspiritphotography.com
N65 Film Winding problem
I have the same problem and I suspect that is the contact of the door.
Taking photos
jeep111
be sure batteries are good. pull up on the rewind knob to open film door. load film ,push down rewind knob. pull enough film to connect to take-up spool. close film door. advance film to counter # 1. look through finder and set meter ( push shutter button to turn on meter ) focus subject and fire shutter repeat to end of film. push rewind button ( bottom of camera ) rewind film.
remove lens by pushing button and turn lens left to remove.
2answers
Nikon F60 Film rewind uncoded film help
Most manual cameras have a button to release the film on the bottom of the camera, push the button in and turn the rewind crank (left side of the top of the camera) until you feel the crank suddenly turning much easier.
Photography Logo
Top Pentax Photography Experts
Ekse
Are you a Pentax Photography Expert? Answer questions, earn points and help others
