Toddler placed coins in the disk slot. The Wii menu will come up but won't read any discs. I can hear the coins rattling around in there.
I would not advise using the drive if there are any loose objects
inside. Doing so would void your warranty, cause damage to the wii, and possibly even bodily injury. If the disc should come into
contact with the loose object while spinning at high speed, the disc
could shatter and the shards may actually break through the drive
casing.
A loose object, if it catches something traveling at high velocity, can easily damage the casing and the wii remember
The only practical solution is to remove the drive from the wii
and obtain a replacement. It would be prohibitive to try to fish out
the loose object, since you might damage the internal components in
doing so. you will need to call Nintendo ( 1-800-255-3700) and see if they can fix it or guide you through taking the disk drive out
I don't think they will slide out if you turn the MBP on edge. I would
take it to the Apple store and be prepared for a nice bill. I hear kids
also do this in the disk player in the car to get it fixed It won't be cheap, I 'm afraid,
At the very least the drive will need to be removed, I fear. It may
actually have to be replaced. A few hundred dollars, I would guess.
Good luck
Testimonial: "I sent it off to Nintendo to fix for $76.00. Not as bad as I thought."
Same thing happened to me, disconnect everything but the power .... then hit eject an gently shake it out. keep hitting eject... an they will come out.
