My keurig b200 is stuck in the mode saying that is "heating please wait" nothing seems to be happening i dont have the user maual. is there a way to reset the machine?
It is most likely the 12v air pump not working. It doesn't provide the air pressure to pump the water into the heating canister and, thus, the unit will try to heat the water indefinitely. See the following forum; it's about the B70 but much useful info, including sources for the air pump that you most likely need: http://www.singleservecoffeeforums.com/dissassembly-repair-guide-keurig-b70-platinum-t8124.html
FredF
SOURCE: b200 stuck. says "brewing" but
Hi.You
may try this steps.
took the reservoir off,
siphon
water from a hose, blow it off
Maybe that
is what has happened in
all of
these instances
cup of coffee.Hope this helps.
SOURCE: how long does it take for the keurig b200 to warm up?
The water reservoir tank probably isn't seated properly. Try wiggling the tank a bit and if that doesn't do the trick, completely remove the water reservoir and then replace it. Once it's seated properly, it should start drawing water and brew as designed. This seems to be a design flaw with this particular model, so periodic adjusting of the water reservoir may be necessary to ensure it is seated properly if your problem persists. Hope that helps! Best of luck...
Here is a tip that I wrote
that will give you some things to try that will help you get your
Keurig coffee brewer working again.
Keurig
Coffee Brewer not making a full cup of Coffee
heatman101
