I have a 250GB 2.5'' SATA HDD from a Toshiba Qasmio laptop that I need to extract data from. I have been advised to use a HDD docking station, and I see that there are many available. Can someone advise me on a good make (cost is not a problem) and whether they are universal because the connection on the HDD in question is on the side and not on the top, so I do not see how that can dock. All manufacturers make the docking and data retrieval process sound so easy, but are there any problems? What about the passwords that were on the computer it came from - do they cause a problem in accessing the HDD? Also, is it an advantage to go for an eSATA station rather than a SATA. Pardon my ignorance, but I want to learn. Thanks in advance.
You just need a an external case that supports 2.5" Sata harddrives and they will connect to your computer via USB.
haven't seen a harddrive that has the connection on the side ,it is usually at the back ,it could be some sort of a Toshiba adaptor that you might have to remove.
The back should look like this :
http://www.gearxs.com/gearxs/images/MK8034GSX.jpg
There are many brands ,coolermaster ,nvidea etc ,some have USB ,firewire and eSata connectors (your PC has to have firewire and eSata in order to use them) The USB ones are usually cheaper.
As far as the password problem goes you can take ownership of that drive by using the security tab on the specific folder that you cannot access but this depends on which operating system you have .Windows XP pro and Vista home and upwards can do this.
Yes you will be able to copy the information but you might get an access denied error on certain folders ,they are the password protected ones.
If you have windows XP professional you can activate the security tab for that folder :
http://mycomputerdidwhat.blogspot.com/20...
For Home edition you will have to do it from Safe Mode ,to take ownership you can use these steps :
http://support.microsoft.com/kb/308421/e...
Yes, you are right, I have just checked my hard drive with the picture you have linked - and it is the same. It is actually a Fujitsu HDD made in Thailand - what next ha ha.The computer I have taken the HDD out of has a windows vista home premium operating 32-bit operating system, so I assume I will be able to overcome the password problem with a good external case. But will I be able to transfer the data - pictures and films etc into a compter with Windows xp, or will it have to be also into a computer with a vista operating sytem? Thanks again for your help.
Thanks - you have been a great help.
