Question about Garden
Don't know exactly where to grease gears.
Where and how am I supposed to grease gears and "maintain" housing on self propelled mower? How far do I tear it down and what kind of grease or oil do I use?
Posted by margiedobbin on
  • Anonymous May 26, 2009
    i have a silver series self-propel lawn boy which i love. small problem that i would like to know how to address. the self-propel clutch engages belt & flywheels, etc - the rear wheels turn when lifted up but just no traction when on the ground. adjusted self -propel cable on mower. wondering if maybe the self-propel gear boxes need to be greased. they have small nipple type objects protruding the them but too small even for wd-40 straw.....any suggestions or ideas would be greatly appreciated. misplaced my owners manual 7 or so years ago.....thanks so much!
Roger Geer
  • 78 Answers
If its a walkbehind the transmission housing is sealed. DO NOT OPEN
Posted on Oct 29, 2009
Troy bilt xp self propelled not switching gears
Check transmission fluid. Ensure belt is good or replace. Check belt tensioner if installed.
Apr 21, 2013 | Troy Bilt 5.5hp Self Propelled Mower
I have a Toro self-propelling front wheel drive mower. As I was mowing the self-propeller stopped working. I checked the oil, gas, blade but it all looks OK. The filter needs to be replaced but I'm not...
5 Rules for troubleshooting engine problems:
1. Spark
2. Compression
3. Accessories
4. Carbonation
5. Timing
Those are listed in order of how hard they are to do.First check the plug and wire.Now is a good time to change the air filter also.
Step two will require a compression gauge,if you do not have one before you go buy one.Try to start the mower.If when you pull the rope goes back in and pulls tight your compression is ok,if not buy a gauge.
Step three.Check that the cable(kill switch) attached to the handle is in good repair.
Next is the carb.You may need to clean it.Carb cleaner would be my first choice,the spray can type. Now if that still wont fix it.You need to tear down the carb and clean a small screen on the inside.That step is far from fun,but is not very hard to do.
Lastly is to check the timing.This can be done by dissembling the crank case and realigning the gears. The gears are marked so it is not as hard s it sounds.
Should none of that work,look at the belt make sure it is not broken and jammed up in the pulleys.
May 15, 2011 | Toro Garden
Self propell wont work when wheels are in put in grass. I have changes cable and drive belt. what could be problem?
If you take off the wheels, you'll see gears inside the wheels, check for wear and tear. If their Ok, check the cogs and pins inside the cogs on the base (or chassis) for wear and tear
Jun 22, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
How to change oil in poulan 22 self-propelled mower
there should be a drain plug under the mower near the shaft that the blade is connected to... good luck
Apr 07, 2010 | Poulan Pro 22" Self Propelled High Wheel...
Where is the oil drain plug for a poulan self propelled 22 inch 625 series mower
remove spark plug wire from plug,tip machine on its side.look under blade for a threaded plug with a square head where bottom of motor protrudes through deck.on most models you can simply tip machine over far enough to allow oil to drain out the dipstick[filler]tube.
Sep 27, 2009 | Poulan Pro " Pro" Self Propelled Mower
Both front wheels on my craftsman self propelled lawn mower are stripped. How did that happen and what do I need to do to keep the new set of wheels from finding the same fate?
Sears self propelled.......metal gear with plastic wheels.......does ANYONE else think this is ASSINNINE? Typical American cheap azz shyt.
Aug 21, 2009 | Poulan Pro " Pro" Self Propelled Mower
Troy Built 6.75 Self Propelled to Slow
put oil or grease all the shafts and bearings inside and out, if possible adjust the cutter blade contacts.
May 20, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Apr 29, 2009 | Garden
Toro 20016 self propel
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
122 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
