Question about RCA F27450 27" TV
Turned tv on and saw sparks then tv shut down
Only had tv for little over a year and i turned it on tonight and saw sparks and it shut down wont work now at all?
Posted by annie_thmsn on
1 Related Answer
Anonymous
SOURCE: RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Posted on Apr 05, 2008
Won't start when motor is warm. Saw for half hour and shut it off and it refuses to start again
this sure sounds as if it's an overheating problem , this causes the ign ckt to over heat and shut off the spark at the plug , id get a real good look at the cooling fins and make double sure theres no sawdust or other stuff in there blocking up the works , if you continue to run saw to overheat eventually it will damage the ign ckt to the point it wont come back on and saw wont run ,Period.
I use strong compressed air to blow out stuff stuck down in the ribs of saws(wear glasses )
Aug 06, 2015 | Husqvarna 550 XP 50.1cc 16 in. Autotune...
65" Mitsubishi TV
cannot get any sound at all from tv
Jan 28, 2010 | Mitsubishi WT-46805 46" Rear Projection...
Mtd yard machine snowthrower not starting, doesn't sound even like it is firing, new gas, new plug, oil is full, emptied gas tank and ran dry before storing last year, blizzard tonight, help!
First spray a prime down the throat of the carb with the choke in the run position and attempt to start. If the motor hits and runs for a second then its a fuel related issue and you will need to remove and clean the carb. If it wont run or try to run on a prime then it may be an ignition issue. check for spark. If no spark then remove the ground wire from the module and check for spark again. If still no spark suspect the module, if spark with ground wire removed then wiring or switch is the culprit.
And make sure you dont over look little things like... does it have a fuel shut off valve and is it open? Is there a safety key and is it in -place? etc.
Dec 09, 2009 | Mtd Products Yard Machines 158CC Tiller
Vizio L23 HDTV 10A
Sounds like the power supply board blew. You can purchase a new one directly from Vance Baldwin. They are the only parts supplier for Vizio. http://www.vancebaldwin.com/
It's just plug and play. remove the old circuit board and replace with the new one. Not difficult and it should solve your problem for less than $100.
Jul 18, 2008 | Vizio L32 32 in. LCD HDTV
Green screen for 30 seconds, then shuts down
yes you need a new picture tube, those tend to lose there power after a few years.
Mar 27, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
No picture whirring noise shuts off and on
DLP(digital light processor) does not have a color wheel
Oct 05, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
RCA F27450 27" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
