Question about Electric Lawn Mower
My electric lawn mower starts briefly and then trips the circuit
Breaker. When it does this it emits a white, electric smell. Any help is appreciated.
Posted by eliot_waxman on
  • Anonymous Mar 29, 2014
    Starts when not plugged into circuit breaker but not when it is
Anonymous
  • 34 Answers
Check cord from plug to the electric motor.if it has a reset or breaker check for damage. if no obvious damage problem is electric motor.may be cheaper to buy new 1
Posted on May 06, 2009
Anonymous
    Problem Solver:
  • 6 Answers
Motor shot sorry
Lawn mower batter charger blows circuit breaker
I'd try plugging it into another outlet first, then try turning off any other appliances that might be on that same circuit. If it continues to trip the breaker, I'd take it to the small engine shop.
hope this helps
Apr 19, 2014 | Toro Garden
Part way through a mowing my electric mower trips breakers deck is clean
motor is probably drawing to many amps and overheating have to change voltage regulator
May 22, 2013 | Garden
I have an earthwise 12 amp electric lawnmower that trip the circuit breaker and now will not start at all. Any suggestions on what might be wrong and how I could fix it
If the circuit breaker trips there are three possible reasons
1. the motor is being overloaded - clean underneath ( as recommended above); or if the grass is too wet or too long or both you may need to handcut; or the motor bearings need lubricating (same problem as me-how?)
2. There is an electrical fault - check the plug and cord (as above) or get an electrician to check the motor and connections; or the carbon brushes to the motor need replacing
3. You have a faulty circuit breaker! - borrow and test with a replacement
Apr 11, 2012 | Electric Lawn Mower
I have a Black and Decker Electric Lawn Mower MM525. Trips breaker when I start it.Was working great,Started it again and now it trips breaker. Mike
the brushes in the motor may be shorting out. check or replace the motor brushes. be sure cord is not the problem.and check the plug also. good-day !
Oct 16, 2011 | Black & Decker 19" Electric Lawnhog...
My lawn mower just stopped working. I was mowing along and it just stopped. It is an electric Black and decker. I was mowing regular grass, nothing complex. It was working fine before that. It is very new...
Open your circuit breaker box. Locate the breaker that has tripped. Turn the breaker OFF (it is in a mid position). Then turn it back ON. Before you do that you need to ask yourself, why did the circuit breaker trip? They trip because of an overload of current. Is something else running on that same circuit, say for example an electric heater or something similar? Depending on the rating of that circuit breaker (15 or 20 amps) you may be drawing too much current. Look for anything else that could be running on the same circuit (only so many outlets can be put on the same circuit). Disconnect or turn off all other devices. Attempt to operate your mower again. If the breaker trips again, then there is something wrong with your mower (electrical short?).
Nov 29, 2017 | Electric Lawn Mower
Electric lawnmower trips circuit breaker as it gets up to speed
Hi Dogtown,
Cool name. Been there. Went to a heavier gauge extention cord and made sure nothing else heavy was on the same circuit.
Problem disappeared.
Best regards
Aug 14, 2010 | Electric Lawn Mower
Replaced switch but circuit breaker trips on start up ! Mowermm600
Your circuit breaker will trip because of two main reasons:
  • Electrical power point circuit is overloaded (too many appliances active on the same power point circuit)
  • Power Lawn mower has become unsafe as your active live is able to reach your earth connection (e.g. short-circuit). Make sure that you have correctly reconnect ALL your power leads wires (check that the Active and Neutral wires have not been transpose). With power off/device unplug, use a multimeter on resistance range and verify that your active lead pin is not showing a reading against the Earth (middle) pin when the mower switch is turn on or off! There should not be any resistance reading between the Earth and Neutral (opposite pin to Active) pins either!
Hope it helps.
Aug 01, 2010 | Black & Decker Garden
Electric lawn mower repeatedly trips house circuit breaker
The breaker is tripping because there is a short in the mower electrical circuit -- most likely in the motor winding -- it overheated.
If you have a multimeter measure the resistance (ohms) of the motor winding by putting the meter probes on the two flat prongs of the power cord with the mower switch on. If you get near zero ohms, the winding is shorted -- motor "burned up".
Using the multimeter again, check for continuity between the round ground pin on the power cord and each of the two flat prongs. If you get continuity on either of these, there is a short to the mower chassis. This can probably be corrected without much expense.
My bet is on the motor winding being shorted.
Charlie
Aug 20, 2009 | Craftsman Garden
Electric Lawn Mower Logo
1,857 people viewed this question
Top Electric Garden Experts
dannydoesita
Martin Grech
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
