Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Green horizontal lines on screen no picture
I have a mitsubishi wd 52525 rear projection tv it was fine last night turned it on this morning no picture just green horizontal lines the menu and volume works just no picture please help
Posted by stacywood81 on
  • Anonymous Mar 16, 2014
    Red radiating out lining the figures and picture on our 46" Mitsubishi rear projection TV
Nate Stansfield
  • 11,896 Answers
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
Posted on May 06, 2009
Mitsubishi WD-52525 was working fine and now it will not turn on
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen and steady green status light.
mitsubishi will rebuild the chasis for $200 with a 6 month warranty
mits.parts 1-800-553-7278
fax 1-706-654-4299
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green Lines with Picture behind
Could be serious...but first check the screen modes (for split screen, format, etc) to be sure the tv is set up properly for the picture you are trying to watch. Switch the input to a DVD or something similar. Is it the same? If not, you have a mode/resolution problem with the tuner and perhaps some other device.
Jun 28, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No picture
If i am to understand this correctly, this is a rear projection television. Inside there may be 1 - 3 " color " control boards that control the picture before going on to the projector. an accumulation of dust / dirt / debris has adverse affects on electronic componants, make sure they are dust free (compressed air cleans them off quite well. If using a home compressor, make sure there is a vapor filter to remove water from the airlines.)
If they are clean, and as you said you recently had the television serviced to replace the projection lamp, take the television back to the repair shop to have them determine the problem.
If you yourself replaced the projection lamp, be sure to check all connections are properly seated if you had to disconnect something, make sure they are in the proper places, and any connections are securely connected.
If all else fails, have a local electronics / television repair person check the unit for faulty componants.
May 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green screen
sound like a DM or FMT board failure. this is not the 4 cap blinking green light problem. check out
www.tv-techs.com
Nov 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 with green horizontal lines
You need to replace the capacitors on the FMT PWB this is a common problem with the V26 chassis which is what your model number is. They have some bad capacitors that need to be Changed. There is a repair Kit available for the FMT repair.Let me know if you would like the link for the repair Kit. Please respond to this same post if you do want the repair kit which does involve soldering.
Jul 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
No picture
Same problem, worked fine this morning and then tonight I million green horizontal bars - sound is fine. I think from reading up on this we are doomed. I am so pissed, the TV is not even 2 years old.
Oct 01, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
403 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
