Question about Cobra 148 GTL 120-Channels Base CB Radio
Power issue no power
I have a 12volt cobra 148gtl dropped a negative across a postive and blew my 2amp fuse replaced fuse with new 2amp and now no lights on cb have power @plug has 12.4 volts any help or direction would be greatly apprecated thanks
Posted by seanbenn007 on
Mike Charette
    Genius:
  • Cobra Master
  • 1,847 Answers
Change the reverse polarity diode.
Posted on Feb 16, 2015
5 Related Answers
Anonymous
SOURCE: cobra 148gtl
tomcat 1 back ...i have found the fault no modulation on am/usb/lsb.tr -23 a bc458 transister .replaced this transister and wow modulation on all 3 modes thanks zeppfrog for telling me where to look .
Posted on Mar 01, 2007
Anonymous
SOURCE: how do you replace the meter light in a cobra 25?
You need to open the unit up ( remove the case/cover). Then remove the 4 screws holding the face plate on. Remove all the knobs ( they slip off) . remove any screws holding the meter on ( there may be none depending on which model you have ) . slide the meter out of the face plate and replace the meter with a new meter. Note: The meter light needs to be reistalled in the new meter. It simply slides out the side of the old meter and slide back in the new meter. Replace all the screws, and the jobs completed.
Good Luck and a good weekend to you.
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 07, 2008
Anonymous
  • 9 Answers
SOURCE: Cobra 148GTL Missing TX Modulation
The problem is most likely the audio ic . open the radio and see if the diode 44 is blown or see if you see anything that looks like it got hot around the plug area. if not contact me and i will buy it. is it an old or new 148 gtl.Read more
Posted on Dec 06, 2008
Anonymous
  • 14 Answers
SOURCE: CB keeps blowing fuses
There are a few common reasons the fuse keeps blowing:
1. The transmitter final transistor is bad, it usually is directly connected to the 12v source and not switched by the power switch.
2. The power wires were accidentally reversed I.E. positive to ground, neg to 12v. There is a protection diode on the circuit board that did its job and is now shorted. it will keep blowing fuses until its replaced.
Posted on Jan 01, 2009
Don Reiman
  • 773 Answers
SOURCE: cobra 29 ltd classic cb not transmitting
Check the ground. Make sure its grounded well on bare metal. To see if the ground is bad, or not making good connection, disconnect the antenna and turn it on. if it does not power up, that means your ground is bad, and it was grounding only through the antenna.
Make sure not to key up with out the antenna connected.
Posted on Feb 08, 2009
My toyota corolla 97 batery was been wrong connected ,(postive to negative ,so now It dosen't start,no windows power,etc ,the only thing that works is the door alarm sound and the emergecy interm
Check all the fuses. You more than likely blew some main fuses. I think there are a couple near the positive battery cable end.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Apr 02, 2013 | Toyota Corolla Cars & Trucks
Need Cobra 148GTL with Cobra HG M75 pin-out color code
1audio. 1red
2shield. 2shield
3receive. 3blue
4switching. 4white
5transmit. 5black
Hope this helps
Jul 03, 2012 | Cobra 148 GTL 120-Channels Base CB Radio
I have a cobra 29 that is new and wont power up when wired up
hi have you tried checking the external fuse to the back of the unit, if i remember ( as it was such a long time ago ) i had an older version of this and there was a screw type fitting on the back ( normally black ) that houses a small 2amp fuse, check to see if this has either blown or broke, there is also an internal one on the circuit board this is also a small 2amp fuse, if it voids the warranty i would not do that one, the other option as it is new is to get a replacement...hope this helps
Feb 22, 2010 | Cobra 29 LTD CB Radio
Cobra 148GTL
Hello k007,
It sounds like you may have damaged the RF power amplifier stage of the CB. Since you were adjusting the antenna characteristics. Did you have a SWR (Standing Wave Ratio) meter connected while you were tuning the unit? If you did you might have noticed the needle go past the 1.2 mark when you were adjusting the antenna or the unit itself. In any event I think that the RF power Amp is shot.
Thank you,
Shuttle83
Nov 04, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Cobra 148 GTL 120-Channels Base CB Radio Logo
225 people viewed this question
Top Cobra Radio Communications Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
