Question about Casio Sea-Pathfinder SPF40-1V Wrist Watch
Need new battery. How do I do that?
Have a Casio Sea Pathfinder sps-201 that needs new battery(s).
Posted by dgreenfi on
Thomas
    New Friend:
    Problem Solver:
First put the battery on a mini charger if there is any voltage left, like 5/10 of a volt or so. If there is any charge then the battery may only need to be externally charged. Sometimes the lithium battery can get so low that the watch charger cannot recognize it - like maybe if it had been left in a drawer for a period of time. In any case I charged the battery on a mini charger for about an hour and the watch now works well. Be prepared to replace the band retainer pins as my were damaged becase they were frozen and would not move in at all so I could remove the 2 metal clasps. Good Luck. Thomas E. Shafovaloff
Posted on Dec 25, 2014
Anonymous
  • 121 Answers
Around the outer edge of the watch there will be an indention. Pry open with a small screwdriver. Your internal compartment should be right there.
Posted on May 05, 2009
Casio sea pathfinder sp60d reset
You need to open the watch and cortocircuit 2 points into the watch machine.
TicTacArea.com is Officla Casio Dealer
Casio Watches
Aug 19, 2014 | Casio Sea Pathfinder Triple Sensor SPF-60
Where can I get a replacement band?
Ebay is a great place for special watch bands. this one is $30:
http://www.ebay.com/itm/CASIO-SEA-PATHFINDER-WATCH-BAND-BLACK-SPF-40-/330812864375?pt=LH_DefaultDomain_0&hash=item4d05fbb777
You can also go to the source, Casio, and purchase a new band:
http://www.casio.com/support/buyparts/
Oct 18, 2012 | Casio Sea Pathfinder SPF70-2V Wrist Watch
How to fix sea pathfinder tough solar SPS-201
If this is the SPS-201 the band is attached so a surfer/sportsman will not have it come off easily. there are stainless steel clasps around the pins and you may have to pry the clasps off and replace the pins which probably can be found at kmart cheap. Bought this watch from thrift for $4 dead. Took battery out checked at .5 volts enough to charge on mini charger. After a short charge replaced and so far it operates fine. Suspect that if discharged too far, from perhaps placing in a drawarer for a while the watch solar charger has trouble detecting + and - poles and charge from my mini charger is just enough to get it going again. I have done this with other batteries. I will have to replace the band retaing pins but that is just about it. Good luck. Suggest when taking apart draw on paper the orientation of band parts and back and tape parts to a piece of paper so as not to lose before reassembly.
Jun 03, 2012 | Casio Watches
After battery replacement of casio sea-pathfinder
If it has "AC" written on the module you may need to short between the AC point and + battery. Also check voltage of battery. It may just be too flat.
Jul 25, 2009 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
I have a casio sps-300 sea-pathfinder watch. I've had it less than a month. Suddenly all the buttons stopped working. The time still runs, and the tide graph works, and so does the hourly time signal. But...
Hi I am a watchmaker and this is a common problem that i have found a lot of times. The watch needs to be opened up and shorted out. With a pair of thweezers touch the AC & the - and this should solve your problem.
Aug 30, 2008 | Casio Watches
CASIO SPF40 battery replacement
"AC" means All Clear. This terminal should be marked somehow. Use a magnifying glass to get a good look at what you are working on. My Casio had an arrow pointing to four copper leads. I used a paper clip to connect the AC terminal (I just picked one of the four) to the + side (usually the "up" side) for a couple seconds and my Casio Sea Pathfinder model 2273 powered right up. See the following link for more guidance.
http://www.geocities.com/watch_crazy/battery/battery.htm
Feb 24, 2008 | Casio Sea-Pathfinder SPF40-1V Wrist Watch
Casio Sea-Pathfinder SPF40-1V Wrist Watch Logo
777 people viewed this question
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Ekse
Bruce Robin
Are you a Casio Watch Expert? Answer questions, earn points and help others
