Question about Nintendo DS Console
My ds wont start up
It will not even go to the menu screen. i will start it up then it will turn white for a sec then cut off. ive charged it ive done almost everything i can to fix it any help?
Anonymous
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 84 Answers
Does your PS3 have good ventilation? that sounds like overheating place it in an open environment but keep it out of extreme temps,If you still have troubles with your PlayStation 3 call 1-800-345-SONY (1-800-345-7669)---usually you can get it to work again by pressing the on and off button repeatedly and in different number of combination’s like holding the power button down for a few seconds, or quickly pressing it sometimes it works after a few tries but sometimes it doesn’t at all. if you do happen to get it to work there is a reset system button
Posted on May 05, 2009
My ds lite just switched off and it was charged
Hi, so if you try switching on the ds lite, nothing at all happens ??
Does the green light flash even if it is for like a split second.If it does then it is more likely top be a blown fuse. If 1 of your screens flicker also, this could be your problem as the ds will not start up with a broken screen. Please advise
Jul 31, 2012 | Nintendo DS Lite Console
My ds wont turn on, but the green light comes on and the screen flashes white and then it shuts off.
keep it in the charger even if its fully charged then while the charger is in start it up
Apr 27, 2011 | Nintendo DS Lite Console
Repair action replay
I done this before and it works.
1. Start it up 2. After the "WARNING HEALTH AND SAFETY" (but before the Action Replay menu) Push "A"+"B"+"START"+"SELECT"
That should completely reset it. Happy Fixing :u)
Oct 31, 2009 | Datel Action Replay for Nintendo DS
Powers on, Controller wont connect, nothing shows up
switch the hard switch off in the back of the ps3. unplug power cord... press and hold power button located on the front f the ps3 for approx 10 secs, then let it sit for a few, then hook it back up and turn the hard switch back on and try to power it back up.
I have had this happen once before but it did return to normal.
Nov 14, 2008 | Sony Playstation 3 (PS3) Console
Nintedo ds wont turn on
why is my screen white
Jul 22, 2008 | Nintendo DS Console
My top screen wont work
Your ribbon cable may be damaged or it might have come loose from the board. The LCD might also be bad. Either way the system would have to be taken apart and this is an undertaking on the DS. If it's under warrenty call Nintendo and have them replace it. If not you'll want to find a repair center. I've done these repairs many of times and unless you really know what you're doing with the DS it's easy to break it much worse than it started out. There are plenty of these on ebay where people have simply made it worse.
Jul 09, 2008 | Nintendo DS Lite Console
Nintendo DS Lite won't turn on.
i would go to the palce and try to return it if you have a promblem because every nintento has a warranty so you should be able to get a new one.
May 13, 2008 | Nintendo DS Console
Ar ds broken
It wont be your DS causing the problem its the cartridge, ive got an Action Replay and it works like a charm, your best taking it back where you bought it from and get a replacement
Apr 22, 2008 | Nintendo DS Lite Console
Power
the backlight is dead. Ihad the same problem with my original DS. This can be repaired but you will need to find a part source for a ds light backlight, try ebay. A lot of parts for newer consoles are hard to find. Even for me and I know how to repair a lot of it.Or try replacing the backlight with LED's
Jan 24, 2008 | Nintendo DS Lite Console
Won't power up-flash of light on bottom screen then nothing
if yr DS is less than one year old, call nintendo and ask for an advanced replacement.... they are good about it and will explain the whole process to you....the number is 1.800.255.3700.... i think it is option three for DS problems, then zero, and the will set it up.... ive had it done like three times....
Nov 27, 2007 | Nintendo DS Lite Console
Nintendo DS Console Logo
99 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Anon
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
