This printer was working fine for years. Today it started printing crooked vertical lines, black only printing. Aligning Print Cartrides routine prints A and B sections OK, but C cannot print a straight line. Changed black cartridge and still fails the same.
Any help is welcome, Mike
SOURCE: alignment page is printing crooked
Normal
0
I suggest you get a sheet of Card Stock (Heavy
paper) and place it in the feed way. Then press the print
button applying a slight amount of pressure on the Card Stock so it
will feed through the printer. The reason for this is in some cases I
have been able to clear the paper track of debris that was deposited there
over time.
Worth a try, as I have fixed a number of printers this
way, saving costly repairs.
Hope this helps.
Bud
A long black line on scanned images is usually caused by a piece of trash on the scanning mechanism.
Look at the scanning arm (the thing that moves when you scan something) and then see if it has any trash on it. If it looks good then you may have a mechanical malfunction in that part.
Let us know hat you find.
SOURCE: hp officejet 7310 won't print in black
You people are stupid! After the first person detailed the problem, why do you reiterate by saying "me too, me too"? People come here looking for answers, not more of the same. Here's a suggestion. If you don't have a solution, don't say anything!!!
SOURCE: HP 6000 Won't print with yellow cartridge
Try this :
Take out the power cable from the back of the printer keep on tapping the power button for 30 secs ; then plug it back.
Take out the catridges clean them with a Lint free cloth (copper contacts); also clean the catridge slot of the printer; put in back the catridges ;
Unplug the power cable from the back of the printer; press and hol down the (#) and the (6) button simultaneously with one hand and with the other hand put in back the power cable; and then release the (#) and (6) button;
It will perform a reset on the printer
IF still then it doesn't work then the catridge slot's copper contacts has gone bad and need to replace
Regards
Soumajit
