You can use refilled toner cartridges or off-brand compatible toner. The plus side to this is they are far cheaper and they do work. The down side is that they may increase wear on your printer and if they are the cause of a printer malfunction your Dell warranty is not required to fix the problem. It's a calculated risk--one which I personally take (three or four replacements of toner save enough to buy a new printer).
Testimonial: "WITH MANY THANXS"
Call now at dell printer support phone number 187777@88969 anytime & get fast resolution at dell printer support phone number works in usa.
You can get refillable toner cartridges for a cheap price, but your printer pays off the rest with abuse. I would recommend always using the proper ink cartridge, it will prolong the life of your printer.
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the cartridge is not contacting to the board .It can also be poor ink cartridge contacts.remove reset and repeat once again.
