It can be done, but I would suggest a tech since if it's not put in properly the new one can be damaged and you will be back to the same spot your in now.It can be done, but I would suggest a tech since if it's not put in properly the new one can be damaged and you will be back to the same spot your in now.
You can't post conmments that contain an email address.
My 20 year old electric Jenn Air range recently flashed the F7 error code and beeped repeatedly. I shut off the circuit breaker until it cooled. The next day I turned it on and everything seemed fine. We baked a pizza and the erro repeated when the oven was shut off. I opened the front panel and noticed the wire ribbon connecting the front panel to the display was slightly askew. How that happened is beyond me. I pulled out the ribbon hold down clips, pushed the ribbon in all the way, and replaced the hold down clips. The range is now working properly after replacing nothing. The cheapest fix possible.
self cleaning uses above normal cooking temps
check how many amps your stove is rated for -40 amps ?
see what size breaker you have 30amp ?
call electrician
hope this helps
is this something I can fix myself or do i need a pro
