Lexmark X5150 All-In-One InkJet Printer Logo
Posted on Oct 08, 2007
Will not print
Every time I try to print, I get a message saying the printer is open. This was ever since I changed my cartridges. The scanner works just fine.
Anonymous
Level 1:
  • Contributor 64 Answers
  • Posted on Oct 08, 2007
Anonymous
Contributor
Level 1:
Answers
64
Questions
0
Helped
93745
Points
96
Try lifting the unit asif you were going to change the cartridges and you should see a gap where part of the chasis will hit a contact, get a can of compressed air and blow into this gap. this should dislodge the contact and put it back to its normal position Hope this helps Copes [email protected]
1helpful
I have replaced all the ink cartridges and my printer says "no cartridge, open scanner cover"
It is probably best to replace cartridges individually as necessary. Let me explain. The printer display will tell you when a cartridge is "xx near empty" and when "xx empty" (where xx is the cartridge color).
1) Near Empty - you can continue to print. This message is to remind you to get a new "xx" cartridge and have it on hand.
Replacing the cartridge when "Near empty" will cause the machine to report "xx Empty" when it is not. It will not register that you have replaced it at "Near empty." Wait to replace the cartridge when you get the "xx empty" message.
2) XX Empty - you may not be able to continue printing. Replace cartridge "xx" now per your manual.
If you have replaced or reseated more than one cartridge, and you get the "no cartridge" error, you need to find out which one the machine "thinks" is problematic:
1) With the scanner cover open and locked in the "Up" position, the message may change to "Change cartridge, install xx" (xx refers to the color )
2) After changing the suspected cartridge and closing the scanner cover, be sure to notice the display. It will say, "Changed XX? 1. Yes 2. No" Press 1.
If all this explanation does not work, keep it in mind for next time. Brother says to unplug the machine for at least 10 seconds, then plug it in again. If the display shows the date and time, problem solved. If not, you may need to contact brother support.
Can't find "cartridge error 50C" in my Dell owner's manual
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
1helpful
Error 50 c
  1. Power off your printer.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Hope this helps.
1helpful
LEXMARK X5150 CARTRIDGE ERROR
Try this --
Cartridge Error 50C
Cartridge Error
1helpful
The scanner cover is closed, however I get an error message saying it's open. The unit will not print, copy or scan
I just changed the cartridges, however I get an error message saying " Cover open / close cover / change cartridge " error . The unit will not print, copy or scan. Any suggestions? Thanks
4helpful
Error code 50c
Cartridge Error 50C
  3. Uninstall and then reinstall your cartridges.If this does not resolve the issue then try the next steps.
Ink cartridge problem
5answers
Cartridge problems
Clean the heads, printer is not reading new cartridge or refilled cartridge. You may also have a paper jam if alignment is affected. Check for little jams, post back if no go lilacgerry xxx
2answers
Error message; no printing of text
What application were you trying to print from at the time. Does the printer give this error message all the time or only from this program? I need this info to assist you bzoe...lilacgerry
LEXMARK ALL-IN-ONE PRINTER X5250
YOU RUINED IT, REPLACE THE PRONTER.
Top Lexmark Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
