Hi, Since you did not provide a model# for your TV I will guess the picture looks like a 3D shape. If the Red, Green and Blue colors are separated from each other then, the convergence circuit is the problem. The repair may cost between $185 to over $200.
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Thats a common problem with rear projection TVs which means the convergence ICs have failed. Replace both ICs and that should takke care of the problem, be sure to check the feed resistors also.
