It was working until my teenager got off the computer and now it doesn't any longer. I have gone threw all my programs and it says that it is uninstalled. I have no idea how to get it back.
My speakers and mic are not working - I did a symtom tree check and I was able to hear threw my headphones on most items just the analog sound playback, surround sound and reord and playback tests were my problems. I heard nothing from the surround on either speaker or headphones. it then gave me error codes and said to get in touch with a tech support ...
I use Dell Dimension 4600 purchased October 2004, warrenty gave up October 2008. The error code is 1B22:0F1B on the surround sound playback test. I am trying to find the spot that tells me what is the name of the sound card that was uninstalled (according to my pc) I think it was a Sound Max something or an other.... my memory is failing me.I use Dell Dimension 4600 purchased October 2004, warrenty gave up October 2008. The error code is 1B22:0F1B on the surround sound playback test. I am trying to find the spot that tells me what is the name of the sound card that was uninstalled (according to my pc) I think it was a Sound Max something or an other.... my memory is failing me.
Looks like my Multimedia Audio Controller is uninstalled. I have tried putting in my cd that came with the pc at first purchase, yet that hasn't worked. I am positive I am doing it wrong. Help?Looks like my Multimedia Audio Controller is uninstalled. I have tried putting in my cd that came with the pc at first purchase, yet that hasn't worked. I am positive I am doing it wrong. Help?
and what was that error code, what kind of computer model # and operating system are you using? and what was that error code, what kind of computer model # and operating system are you using?
You can't post conmments that contain an email address.
One possibility is the temp sensor,if it does know it's a cold start ,it won't have an enriched fuel mixture to start.
Change it or put on a scanner and look at the temp sensor reading when cold.
Manual code entry 1.Turn on your television or other electronic component that you want to program the remote control for. 2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on. 3.Hit the button for the component that you are programming (TV,DVD VCR, etc.). The LED light should flicker and stay on. 4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have. 5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off. Auto configuration 1.Turn on your television or other electronic component that you want to program the remote control for. 2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on. 3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on. 4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press. 5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
Sounds like the driver may have gone corrupt
Try to uninstall and reinstall the drivers/software.
Be sure that the device is not connected to the computer until the software prompts you to plug it in
If this solution has helped you, please take the time to rate me.
common problem with people that do not let out the clutch at lights and put it in neutral. they sit at the light with the clutch pushed in. it wears out the clutch springs and burns the clutch.
If you have a voltage meter you could see where the problem lies. All TriStar parts including the motors, both the nozzle head motor and the actual vacuum motor are purchaseable online through www.totalvac.com
I have ordered parts through them and everything arrives no problem and they are priced nicely by the way.
It happened to me once before.
So I formatted it threw the program that came with the device and then I copied my music files once again while the program was working. After that everything worked just fine.
Hope it helps!!
