Question about ZEEPAD 7 inch Android 2.2 Tablet
Can't get driver loaded for Zeepad 7 9XN
It's working fine on it's own - Wi-Fi, etc. Can't get driver loaded. Widows error 43 unknown device. I've downloaded from the website but it won't load the new driver - it keeps telling me I have the correct driver already but it doesn't recognize the device. Can't proceed with the flashing software because it says the driver is wrong
Posted by Paula Whikehart on
Jeff Bird
  • ZEEPAD Master
  • 1,346 Answers
Hi code 43 can occur if the device driver fails uninstall the driver ,& install a new driver .cheers
Posted on Nov 05, 2017
1 Related Answer
Gerald Goonting
  • 24 Answers
SOURCE: I cant get to any websites on my Zeepad.
Try to restart the zeepad. Go to network settings and reset the settings. Setup the network again and restart it. Should work....
Posted on Nov 07, 2014
I factory reset my zeepad, 7DRk-Q. Restarted the device. Wont let me sign in to any google apps.
Please make sure you are connected to your network. Let us know? Thank you. Please leave feedback
Jul 10, 2016 | ZEEPAD 7DRK Dual Core 4.2 Blue Android...
My zeepad tablet wont connect to my WiFi
This may be a firmware problem. I had this problem. Download a android firmware app. Actually it's called android firmware and updates app and it's free. I don't think these cheaper tablets update as they should, that causes them to not connect to the internet. Why? I don't know. It drove me crazy. I tried everything. My daughter figured it out after messing with the tablet for months.
Mar 09, 2015 | ZEEPAD 7DRK Dual Core 4.2 Blue Android...
I bought 4 ZEEPAD 7DRK Rock tablets for my grand kids for Christmas and 2 of them will not even turn on. The 3rd one worked for 3 days and it also will no longer turn on. I've tried charging them...
Hi, Zeepads have an issue with powering on....when charging it is best to use the mains charging as it is more powerful....if you are sure they have been fully charged then try this:
Hold the power button down for about 2-3 minutes.
Listen for a small click.
Take finger off of power button and wait for about 30 seconds.
Hit the power button again.
Hopefully you should see the start up screen, post back with the results!
Jan 01, 2015 | ZEEPAD 7DRK Dual Core 4.2 Blue Android...
What is Zeepad Customer Service phone number?
Sorry to say, Zeepad's website (zeepad.net) has had it's contact us and about us links deliberately removed. Also it looks like the domain is for sale (http://whois.domaintools.com/zeepad.net) I am also pretty sure that the site is hosted in China a so good luck contacting them.
Dec 26, 2014 | ZEEPAD 7DRK Dual Core 4.2 Blue Android...
How do I set time 7date on Zeepad7drk
You can set the time in your zeepad by going into menu , tap setting, select date and time and then set the time zone in your country.
Dec 05, 2014 | ZEEPAD 7DRK Dual Core 4.2 Green Android...
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
How to turn on the Wi-Fi on a Zeepad 9XN?
There should be a way under the settings button.
Aug 22, 2014 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
ZEEPAD 7 inch Android 2.2 Tablet Logo
90 people viewed this question
Top ZEEPAD Tablets & eReaders Experts
Harrie
Sean Cole
Sean Cole
bobalix
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
