So I have a Roper Washer not sure what model it is. Just know it used to get the washing job done on my clothes.
So whats happening is .... The washing machine wont go thru the spin cycle. It stops when it reaches that point. Like it will go through the rinse, then stop when it gets to the spin.
Do you know what could be the problem?
Probably a bad lid switch. Open the control panel. Disconnect the lid switch wire connector on top of the cabinet under the control panel. Make a small insulated jumper wire and insert it into the wire that is still connected to the control panel. Set the timer to spin. If it spins replace the lid switch in the cabinet. If not, replace the timer.
