Question about Mitsubishi WS-65869 65" Rear Projection Television
Tv won't start
I plug my tv but when i go to start it it won't do anything
  • Mitsubishi Master
  • 19,396 Answers
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
    Problem Solver:
  • 7 Answers
I have your solution! Its called a Certified Mitsubishi Technician. Call me when you get a chance and ill be happy to help you. 714-457-9430
Posted on May 21, 2009
Anonymous
SOURCE:
Car won't start
If you have checked fuel pressure with a gauge and the pressure is normal, are you getting spark to the plugs ?
Apr 30, 2013 | 1997 Pontiac Bonneville
97 Nissan 200sx turns over but won't start.
check coils, plugs, clogged throttle body, vaccume leaks, or anything else that would enable from starting.
Mar 30, 2013 | Cars & Trucks
TV won't turn on
Do you have any lights on on the front of the TV? anything flashing? Or is it just dead?
Mar 21, 2013 | Mitsubishi WS-55511 55" Rear Projection...
Truck won't start at all changed starter have cleaned all electrical plugs truck won't do anything
try selionoid..bump the neg and positive together with a screwdriver..if it cranks walah go get another selionoid
Nov 21, 2012 | 1993 Toyota Pickup
Tv will not turn on
This sounds like it might be a main board issue. Depending on the television brand there are different replacements you can get at different prices. I would try unplugging the tv from the wall first then try plugging it back in while holding channel up/volume up on the tv as you are plugging it back into the wall. If this doesn't change anything it is most likely a problem with your main board.
Jul 23, 2012 | Vizio VO47L 47 in. LCD TV
JVC AV56P776 Projection TV Green Light Flashes Won't turn On
Could be an open internal fuse or power supply failure
Jun 17, 2017 | JVC Televison & Video
Technika 32-270 LCD TV won't stop scanning
Need help stopping scan on tv, won't turn on and no remote will activate anything on the monitor. Help flat screen tv.sanyo keeps on percenting
Dec 31, 2011 | Televison & Video
Visio light on front flashes on and off tv won't come on
Unplug your TV and then plug it back in, let it flash on and off without doing anything for 5 minutes or so and then turn it on. It does it once amonth or so for some reason.
Nov 24, 2011 | Vizio XVT3D474SV 47 in. 3D LCD TV
Accidentally put mixed gas and tried to start. Blew white smoke after starting but wouldn't run. Drained tank and put premium back in now won't even start.
There will still be some fuel mix in your fuel lines and filter. Also it probably fouled your spark plug. Try changing the spark plug first, and probably buy an extra one or two to keep in case. Also either replace the fuel filter or clean it out good, oil will stick to the elements in the filter. It won't hurt anything to run a mix in a gasoline engine, just lubed things up a little extra. Let me know if you need anything else, Daniel.
Oct 13, 2011 | Polaris ATV
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
181 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
