Televison & Video Logo
Posted on May 05, 2009
Lost everything visual, just audio.
Strange problem. I have Hyundai DVD he-dvr558hd, I was in System Setup, and I selected Video Output Format and changed it to Progressive mode, unlike INTERLACED that he was in. The second I selected that picture is gone. He has all other functions, he tourns up, he can open and close the tray, but nothing appears on TV, i have audio from TV, I try to change SCART positions, and to work in System Setup blind -(nothing shows) but nothing happend. Please help me to get my picture back. Thx very much! Nina from Croatia
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 30, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
239
Points
Just enter the appropriate Menu-Setting (without a picture you´ve to do this "blind") - Press "Setup" - 1x key down (=video menu) - 1x key right (switch to sub menus) - 2x key down(=video format) - press select - key up (=interlaced) and press select again - finished!
Anonymous
Level 1:
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
239
Points
What about connecting the recorder temporarly on a tv set, which supports progressiv scan? When you "see" a picture there, you can switch back to interlaced mode.
Hello. I have my HK connected to a new Sony TV. I see the video pic but hear no sound. I've made sure the TV speakers are on. Not sure what the problem is. Thanks
hi,
Check the connections you have made between the tv and dvd player, whether you have connected the audio output of the dvd player to your tv.
if its ok the go the system setup of you dvd player and then go to the Audio setup.
In the audio setup select digital output and make it to PCM.
exit menu and test
ok
tip
How to rip dvd video to youtube on mac os
Part one : choose a proper video format for youtube
Most of people who have ever uploaded video to youtube came across one of the scentiro: cant upload video to youtube ,or take hours to upload video to youtube.Unfortunately , i am among the one of these kind of people with such bad luck ,and this takes me days to figure out what the problem it is.
For the reason that you cant upload video to youtube is that the video you prepare to upload is not supported by youtue.Go to youtube official documentation for reference. So if you video clip is not in one of these video formats, you cant upload video to youtube obviously.
As for taking hours to upload video to youtube ,the reason is that your video is either too big nor is not in best video format.I have always faced lot of problems in uploading videos to Youtube and eveytime I upload it the video quality has been poor. Since then I always wanted a good balance between video quality and file size.I would recommend following video formats in order to attain the the best quality video for youtube. .
Video Format: MP4/ MPEG/MOV/FLV(MP4 and FLV are my favorites.)
Video Codec: H.264, MPEG-2 or MPEG-4
Audio Codec: MP3 or AAC (stereo channel)
Part two : how to rip dvd to youtube video format
In order to upload DVD movie clips to YouTube, you first need a DVD ripping program to help you extract the video clips from the DVD movie and rip the DVD movie to YouTube friendly video formats like FLV, WMV, AVI, etc. Note: This tutorial only focuses on how to rip DVD movies to FLV format for YouTube video.
Step 1: Free download and install DVD Ripper for Mac.
Step 2: Load DVD to convert to FLV
Insert DVD into your DVD-ROM. Click "Load DVD" button to load your DVD. Just Click "Load IFO" button and press DVD folder or DVD IFO file.
Step 3: Select FLV as Output Format
Use the “Format” on the bottom of the window to control the output format. Click on the toggle to the right of the "Format" label to get format drop-down menu.
Step 4: Change FLV Video and Audio Settings
You can change the Resolution, Encoder, Bit rate and Frame rate of the FLV video and Sample Rate, Channels, Encoder and Bit Rate of the FLV Audio. The size of the FLV file depends a lot on these settings.
Step 5: Select Output Directory
Expand the "Output" panel. Use the "Browse" button to select an output directory.
Step 6: After all the settings, click "Convert" to start the DVD conversion.
on Sep 01, 2010 • Computers & Internet
tip
How to rip dvd to ipod or iphone?
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} As we know, iPhone and iPhone 3GS only support H.264, MPEG-4 in .mp4, .mov, .m4v formats, and MP3, protected AAC, AAC, Audible, Apple lossless in .aac, .mp3, .m4a files. That's to say, you need to rip DVD to iPhone Mac the format supported by iPhone.dvd to ipod
Step1. Add DVD Movie. Launch Mac DVD Ripper, Click the Load DVD Or the Load IFO button, browse your computer, find the DVD folder of the movie you want to add from your hard disc or DVD-ROM, open your DVD folder, select the VIDEO_TS folder and click OK.
After you add your DVD movie, you can choose any titles or chapters you want to rip dvd to iphone on Mac by ticking the check boxes before them.
Step 2: DVD to iPhone on Mac Output Settings At the bottom of the main window, you can name the output file for the current title/chapter, and select a subtitle to put on your movie, select an audio track. Then finish all the settings including selecting an output format for the current title/chapter from the format drop-down list:
clicking the Settings button to set the video and audio encoding settings such as video resolution, video bit rate and audio sapmle rate and so on, choose if to merge the selected titles or chapters into one file, and set an output directory to save the output files.
Step 3: Start to rip DVD to iPhone Mac After setting the output settings, you can just click the Start button to start to rip DVD to iPhone on mac. You can choose to shut down your computer or open the output folder after conversion so you don't have to sit before your computer waiting for the conversion to finish.
I am a computer worker and can help you solve many problems, such as:dvd to ipod,mac dvd ripper,mac video converter ect.
on May 19, 2010 • Computers & Internet
I have a dvd player DP170MW8B and it only plays in Black And White
hi,
goto the system setup and then video setting . check the output system format. if ur system is NTSC select NTSC and if ur SYSTEM is PAL select PAL. also check one more thing,if u are connected the component video output, then check is it connected right or not. there may be chance to interchange the connection. if so this type of complaint can occur. make connection properly. red to red , green to green and blue to blue.
ok
2answers
Setting audio to optical makes hdmi video not work
Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
4answers
DVD Ripping
This is a two part process...
You'll need DVD Decryptor (freeware) and AutoGK (also freeware).
In DVD Decryptor you'll be ripping the DVD movie to an IFO file.
Once that is complete load AutoGK, select the IFO file you just created (it will automatically get the .vob's you just created) select a destination defualt an audio track (usually movies have more than one audio track) and file size and let it go. Depending on the movie it should take approximately 45 minutes to an hour to complete.
The other program you can use after DVD Decryptor is Any Video Converter (also freeware). Instead of selecting the ifo file, select all the .vob files and then right click on the files and select "merge" (make sure they are in the correct order).
This program is a lot faster than autoGK BUT if your DVD has multiple audio tracks, it may not get the right one during conversion.
I believe you can get everything at www.filehippo.com
Hope this helps
2answers
Pictue but no audio on VHS playback..VHS record to DVD visual/no
Hi
please check the format settings, maybe the audio is not in good settiongs!~
Thanks!
SC-RT50 Decoding Surround Sound From Aux and Inputs
The other players need to be setup to output digital sound. Assuming you are using a digital or optical audio cable, go into the setup screen of the Blu-Ray or Tivo etc. and select the audio setup screen. Set the audio output to PCM.
1helpful
Ps3
you might want to try changing the settings settings just go to sound settings>audio output settings and choose the type of cable you're using sfter that select automatic and press X. if that doesnt solve the problem may be you accidentally chage the BD/DVD audio output format. is locate in BD/DVD Settings change both BD/DVD audio output format (HDMI) and BD Audio Output Format (optical Digital) to linear PCM or viseversa try both to see wich one works.
p.s. it can also be a problem with your sound/ hometheater system.
No Audio/Video output with DVDs
lost dvd picture and menu screen through denon av2307 composite conection
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
