When using my frigidaire dishwasher - the water keep backing up into my kitchen sink instead of draining. It also takes alot of time for that water to drain out of my sink. Any ideas?
Yes, your sink drain needs cleaning -- it's clogged. Pour some bleach into the sink drains and let it sit for a couple of hours. Flush out with boiling hot water.
If this improves the situation but not completely solving the drain problem, try it again.
If that doesn't solve the problem, remove the P-traps on the sink drains under the sink and clean them out.
If that doesn't work, let me know -- we'll try something else.
Two things to consider....clean water or
dirty water?
Clean water usually indicates the fill valve
is not shutting off all the way and the fill valve is "weeping" water
in all the time = new fill valve time!!
Dirty water usually is not a dishwasher
problem but more of a plumbing issue. Often the sink drain that carries the
sinks water outside is not fast enough and some of this sink water is backing
up into the drain hose and filling up the dishwasher through the drain hose.
The drain from the sink to outside needs attention as this type of a problem
indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
dirty water?
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
