Sharp 19 in. LCD HDTV Logo
Posted on May 05, 2009
What type of cable for laptop to Tv?
TV is a sharp 19SB25U. laptop a toshiba satellite. What cable to link these ?
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on May 05, 2009
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
19003
Points
70
In order to hook a laptop or any computer to a tv you have to have the right video card with the correct video connections like hdmi or s-video. If you don't have those connections then you can't hook a laptop to a tv.
How do I tune my Sharp tv to channel 3 so the cable will work?
Go to the Tuner setup screen and select cable instead of air. Then put the TV on Channel 3 and connect the cable box to the antenna connector on the TV.
I have a toshiba satellite p755, it use to be able to hook up to my HD TV with the HDMI chord but now its not connecting..whats the problem?
Make sure all connections Power ,HDMI and any other connecting leads have secure dust free connections also check each lead for any kinks / bends .
Connecting a Toshiba Satellite Laptop to a TV is an ideal way to enjoy videos, photos and other media on the laptop on a much larger screen.
Satellite Laptops can be connected to TVs using VGA, S-Video and even HDMI, though the TV has to have compatible inputs as well.
Connect the RGB cable or S-video cable to an open input on the TV.
Depending on the type of TV, it may or may not have a RGB input.
S-video may have to be used instead.
Connect the 1/4 inch to RCA Y-cable into the TV using the same input as the VGA or S-video cable.
Connect the other end of the VGA or S-video cable and the audio cable into the laptop.
The video ports are on the sides of the laptop.
The audio cable should go into the headphone jack of the laptop.
http://www.svideo.com/compaq1700.html
1helpful
How to connect a toshiba satellite L675 to a tv using HDMI cable
If you TV has HDMI connections. All you need is a HDMI cable. Hook the HDMI cable into the laptop and into the TV. Turn the TV on and go to that HDMI connection on the TV. It will show everything on the laptop on the TV. Videos, Documents, and anything else.
Which type of cable I need for Toshiba satellite C660-258 to connect to the TV so that the sound can be heard on TV, not the laptop?
The Tv has the HDMI, in order to make this work the laptop must have the HDMI plug, it carries the audio and video signals to integrate both systems, it is usually located on the side or the back of the laptop.
1helpful
What cable do i need to plug a toshiba satellite L300D into a tv
depend on yr tv and laptop, normaly use hdmi cable to connect laptop and tv
How can i connect my toshiba laptop to toshiba tv with vga to rca
Go to Toshiba site or send email to UK office help.
Requesting the info.
Or type in toshiba to google and surk for the info, it is there.
I don't know if my TV's digital tuner will work when they switch over to digital broadcasting. My TV does have one but during a test it didn't work
The Sharp LC-19SB25U 19 in. HDTV LCD TV has both a NTSC and an ATSC tuner.
The NTSC tuner will stop working in Feb. 2009 but the included ATSC tuner is what you need for after the digital transition.
If this is not the model number or manufacturer of your TV, then please post them.
Laptop to tv
Is your Graphic-card is compatible?
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
