NorStar T7208 Corded Phone Logo
Posted on May 05, 2009
Deleting security code from Norstar Meridian M7208
We have one phone on the network that requires the Feature button to be pressed and a 6 digit security code to be inserted before an outside line with dial tone can be successfully selected.  We want to delete that as the security protection is no longer needed?  How do we do that?
Thanks Andrew Collie
Anonymous
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Jul 12, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
15723
Points
27
Go to programming of Norstar bY Feature**266344 passwordwill be 266344.
Press show put the extension number then show the keep pressing next until display shows restrictions.Press show the next until dispaly shows ext rest. then show then show again and check what is the restriction filter number.
Press heading till u get restrictions.press show then show again. put the restriction filter code and delete or remove all restrictions from the filter and press release and come of the programming.
Restriction has been removed now.
After that u can easily make o/g calls without using any code.
When I press memory buttons on one particular telephone in our office they all dial reception. How do I fix this?
PDF]Telephone Features Programming Guide - Avaya Support
https://downloads.avaya.com/css/P8/documents/100142941 AvayaNORTEL NETWORKS is a trademark of Nortel Networks. ... All other trademarks and registered trademarks are the property of their ... One-line and two-line displays . ...Memory buttons . ... Call anomalies for telephones without line buttons . .... Select how you dial your calls . ... Receive a busy signal on an internal call .
Norstar How to program phone how to program voice mail ...
www.phonserv.com/1_PDF_user_guide_meridian_norstar_phone_syste...
Nortel Networks Meridian Norstar How to program voice mail phone feature codes ...Modular ICS KSU must be programmed with an M7310 or a M7324 telephone. ... Lift handset, press Voice Call key or press the Feature button, then press 66 2. .... At the LOG: prompt, enter your mailbox#(extension #. and your password all ...
[PDF]N QRTEL NORSTAR
Norstar Meridian how to turn on the ringer
From the following web site:
http://www.telephonemagic.com/phone-support/norstar-feature-programming-code.htm
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Nortel Meridian M7208 page not working...
Press Feature * 3
press the 5th line key you want to use for paging
enter the page-all code (feature 601-603 as you wish)
How do you change the time on the display for the M7208?
Changing the time on a Norstar system must be done using a display phone. Using a M7310, M7324, or T7316. The 4 top line/feature keys are now used for programming.
the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___"
12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Handset test on meridian norstar M7310 / M7208 / M7100
Feature 805 is valid on versions 2.0 or above.
1helpful
Meridian M7208. I managed to reset the default
Press feature *3, press the button you want to program back to speed dial, and press feature 0.
2helpful
SCREEN NOT DISPLAYING NUMBERS
If you haven't already tried it, unplug the phone, press a couple of buttons, then plug it back in so it resets. If the boxes still appear, try adjusting the display contrast. Press Feature-*-7 to get to contrast setting and then press 6 or 7 to set mid-range contrast.
3helpful
How do I retrieve recent incoming calls
If you have call log set up you can access the log log by pressing feature 812. To program that feature as a one touch button press feature *3, press the button you what to be call log and enter feature 812
Unable to use conference button
Here are the instructions for making a conference call on a Norstar system.
Conference [Feature] [3]
  • Establish a conference call between yourself and two other parties.
    1. Make or answer the first call.
    2. Put the first call on hold.
    3. Make or answer the second call.
    4. After the second call is connected, press [Feature] [3].
    5. Press the line or intercom button of the first held call.
    6. Press [Rls] to end the conference call
  • To remove yourself from a conference permanently (unsupervised conference):
    • Press [Feature] [7] [0]. The other two callers remain connected. (Some external lines may not support this feature.)
  • To put a conference on hold:
    • Press [Hold]. The other two callers can still talk to each other.
  • To split a conference:
    • Press the line or intercom button of one caller to consult privately while the other caller is on hold. To re-establish the conference, press [Feature] [3].
  • To disconnect one party:
    • Press the line or intercom button of the caller you want to disconnect, then press [Rls].
    • Press the line or intercom button of the remaining caller to resume your conversation.
  • To independently hold two calls:
    • Press the line or intercom button of the first caller, then press [Hold]. The second caller is automatically put on hold. To re-establish the conference, retrieve one call from hold, press [Feature] [3], then retrieve the second call from hold.
3helpful
2answers
How do you page with a Meridian Norstar M7208 phone?
There is another page, acting more like a directed intercom page...
If you want to talk to someone and you know where they are (general area) you can do a FEATURE 6 6 and the extension number.
This is a direct page and when you page this way, that person can respond back and you can hear them.
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
