Cars & Trucks Logo
Jenny Hill Posted on Nov 18, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toyota 4runner 2006 is locking automatically then beeping/head&tail lights flashing every 60 seconds. Won't stop. How do I fix this?
sbarneski
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 74 Answers
  • Posted on Nov 18, 2013
sbarneski
Expert
Level 2:
New Friend:
Night Owl:
Answers
74
Questions
Helped
14122
Points
173
That happened to my wife when I bought her a car (with a factory installed alarm sys) that didn't come with the remote... Any local car alarm installer can reprogram another one for you (which is what we wound up having to do cost us $50) sometimes theres a lil tiny toggle switch under the dash somewhere on after market alarm systems
1helpful
2answers
2006 pt cruiser head and tail lights won't come on
Sounds like a fuse problem. Find the fuse box for the lights and replace the one that is for head &tail lights
I ganged head gaskets on my 92 4runner & it will start but won't stay running
did you make sure all grounds were on and that all the wiring was good
2answers
I have a 1987 toyota 4runner and no running lights or dash lights . The tail light fuse is ok but still no dash lights or running tail lights break lights light up fine.
THE DASH LIGHTS ARE USUALLY CONTROLLED BY A SMALL THUMB WHEEL NEAR THE HEADLIGHT SWITCH ON THE DASH. THAT IS A RHEOSTAT, THAT MAKES THE DASH LIGHTS BRIGHT & DIM. REPLACE OR BYPASS IT.
2helpful
Automatic Transmission locked in park. Will not shift. The vehicle is a 2000 Toyota 4runner with a V-6 engine.
Sounds like the shift lock solenoid is not working, there could be a couple of different things cousing this. First thing I would check is the brake light switch witch is located under the dash on the brake pedal assy.. The second thing it could be is the shift lock solenoid its self, wich is located around or near the shifter.
Need instructions on programming a key fob
Please try this. Toyota - 4Runner . org Forum > Toyota 4Runner Forum > 3rd gen T4Rs > Programming Instructions for keyless entry remote? Pages (2): [1] 2 » Last Thread Next Thread Author Thread rav04 Junior Member Registered: Nov 2004 Location: Canada Posts: 6 Programming Instructions for keyless entry remote? I have a 1999 4runner LTD, can anyone provide me with the instructions to program my keyless entry remote? Thanks __________________ RAV Report this post to a moderator | IP: Logged 12-31-2004 02:11 AM NoliWan Member Registered: Dec 2004 Location: San Jose, CA Posts: 34 Hey RAV, I got your PM-- Here are the instructions for programming the 99-02 4Runner Keyless Entry factory remotes: 1. Start with the following conditions: you are in the vehicle a. Key is out of the ignition b. Drive door is open ( all other doors are closed) c. Driver door is unlocked (other door locks don't matter) 2. Insert the key into the ignition (don't turn it) and pull it out. 3. Perform these steps within 40 seconds: a. Cycle the power locks 5 times. Use an even pace and try to go relatively fast. b. Close, then open the drivers door. 4. Perform these steps within 40 seconds: a. Cycle the power locks 5 times (same as before). b. Turn the ignition to ON then back to OFF. c. Turn the ignition to ON then back to OFF. d. Remove the key from the ignition. 5. Within 3 seconds, the power door locks should cycle (automatically) indicating successful entry into programming mode. Return to step 1 if the locks do not cycle at this point. 6. Perform these steps within 40 seconds: a. Press the LOCK and UNLOCK buttons on the transmitter simultaneously for 1 second. b. Immediately after letting go of the lock and unlock buttons, press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle ( LOCK then UNLOCK) once-- indicating successful programming. If the door locks don't cycle, or cycle twice. Repeat steps 6a and 6b--this remote has not been accepted. c. Repeat steps 6a and 6b for EACH transmitter that will operate the vehicle. Including any old transmitters. 7. Close the driver door. Hope this helps you, it did me greatly-- Good luck, NoliWan __________________ 2000 SR5 4Runner 4WD ____________________ TRD 2nd Gen. Supercharger / TRD Headers / TRD Cat Back Exhaust / TRD Trans. Cooler / TRD Performance Wheels / TRD Boost Gauge / URD Fuel Kit Upgrade / URD 2.2" SuperGrip Pulley / Airaid M.I.T. / DeckPlate Mod.w/ TRD air filter / 1" PP lift springs w/ Bilstein shocks / Brembo Slotted/Dimpled rotors w/ TRD brake pads / Carbon Fiber dash trim / 60XT PIAA Ion fog lamps on manik grille guard w/ PIAA super extreme H4 headlight & H3 foglight bulbs. / Optima 34R Red Top... Last edited by NoliWan on 12-31-2004 at 07:26 AM Report this post to a moderator | IP: Logged 12-31-2004 06:47 AM Serge Junior Member Registered: Jan 2006 Location: Kyiv, Ukraine Posts: 14 Mr. NoliWan, This was amazing Thanks to instructions provided by you I managed to reprogram my new remote in just 10 minutes. Thanks again. Report this post to a moderator | IP: Logged 01-25-2006 09:16 PM trd_style JDM Style User Registered: Sep 2005 Location: Oklahoma City, Oklahoma Posts: 470 HMM!! This thread should be a sticky!! __________________ 1997 Toyota 4Runner 3.4L V6 Report this post to a moderator | IP: Logged 01-25-2006 09:34 PM voltageGSR Member Registered: Dec 2004 Location: Detroit, MI Posts: 43 very helpful I got through all the steps multiple times but when I get to 6B - it cycles twice; i close the door, and the remote doesn't work. i thought maybe battery..on teh remote, etc.. seems to be ok. Wondering where I'm going wrong? I have a 2001 t4r; remote FCC ID is: 1512Y looks identical to the one I lost..but is this not the right remote? thanks guys! __________________ 2001 Toyota 4runner SR5 4x4 Report this post to a moderator | IP: Logged 06-13-2006 12:52 AM uwgrad97 Member Registered: Apr 2006 Location: Seattle, Washington Posts: 60 That's the same remote I have for my '02 Sport. If you're doing the steps correctly, maybe there's something defective with that remote. Report this post to a moderator | IP: Logged 06-13-2006 02:16 AM voltageGSR Member Registered: Dec 2004 Location: Detroit, MI Posts: 43 i bought it from an ebay member who says it works. plus it seems to respond to the remote; but it cycles twice indicating that it didn't take... any hints? I did the steps several times; I think I am doing it correctly.. __________________ 2001 Toyota 4runner SR5 4x4 Report this post to a moderator | IP: Logged 06-13-2006 11:13 PM voltageGSR Member Registered: Dec 2004 Location: Detroit, MI Posts: 43 any suggestions? seems like the right remote - just unable to pogram correctly? could it need a new battery? seems to respond to the system - ..so didn't think that could be the issue. __________________ 2001 Toyota 4runner SR5 4x4 Report this post to a moderator | IP: Logged 06-16-2006 01:05 AM fooldall Junior Member Registered: Jan 2006 Location: Posts: 21 Does this work for a 1997 as well? I just ordered one for my VIP system on my 97 Limited... Report this post to a moderator | IP: Logged 11-03-2006 02:04 PM pat161 Senior Member Registered: Dec 2004 Location: Central MA Posts: 540 I think the remote you need depends on whether or not you have the alarm. The 1512Y did not work on my 02 Sport w/o an alarm. I needed FCC ID# HYQ12BAN. Hope this helps. Report this post to a moderator | IP: Logged 11-07-2006 11:48 AM BoulderZJ Junior Member Registered: Jan 2004 Location: Boulder, CO Posts: 12 This is amazing. I thought my remote was dead, turns out it had just lost it's programming from the dead battery. I followed this and had it fixed in 15 seconds. Yet another reason I'm glad I got rid of my Jeep. Thanks for the help NoliWan. __________________ 2000 4Runner Limited Alpine 7998, XM, MB Quart reference series all around, Rockford amps and subs Report this post to a moderator | IP: Logged 11-11-2006 08:48 PM mryuk81 Junior Member Registered: Nov 2006 Location: Posts: 4 a. Cycle the power locks 5 times. Does this mean lock/unlock 5 times? I am really unsure. Here is some history: Actually, I didnt buy a new remote. Mine stopped working. I have an 02 T4R. Last week I noticed the *chirp* sound wasnt working any more. Over the weekend... the Keyless Remote stopped working totally. So I radio shacked a new battery in the remote... but it still does not work. I tried these reprogramming instructions, but they do not work either. "Within 3 seconds, the power door locks should cycle (automatically)" This doesnt happen. So I am wondering if I am doing the cycle correctly ... Any Advice would be appreciated. Last edited by mryuk81 on 11-20-2006 at 06:20 PM Report this post to a moderator | IP: Logged 11-20-2006 05:43 PM mryuk81 Junior Member Registered: Nov 2006 Location: Posts: 4 Anyone have ANY ideas ? I have tried this possibly 30 times and it has never worked. Could it possibly be something else wrong ? like a fuse or something? ANY Ideas ? Last edited by mryuk81 on 11-21-2006 at 07:29 PM Report this post to a moderator | IP: Logged 11-21-2006 07:07 PM swtrader Junior Member Registered: Dec 2006 Location: Posts: 3 Programming w/ an alarm I have an alarm on my car that the dealer add. It turns on when the driver door is locked. I can't do the steps with out setting off the car alarm, specifically the close and open the drivers door step. Has anyone seen this problem and have a work around? Report this post to a moderator | IP: Logged 12-14-2006 04:52 AM techno WTF Mate? Registered: Oct 2006 Location: Pittsburgh Posts: 828 quote: -------------------------------------------------------------------------------- a. Cycle the power locks 5 times. -------------------------------------------------------------------------------- Yes, this does mean lock then immediately unlock five times. So it will be locked 5 times and unlocked five times. If you were doing this and the vehicle wasnt doing the automatic cycle thing, then there must be a problem with the computer and not the remote. quote: -------------------------------------------------------------------------------- I can't do the steps with out setting off the car alarm, specifically the close and open the drivers door step. Has anyone seen this problem and have a work around? -------------------------------------------------------------------------------- After you do the lock/unlock cycle thing, the doors should all be unlocked, so your alarm shouldnt be going off. Does your alarm always activate when the unlocked doors are closed? __________________ '00 SR5 4x4 ARB Tundra/OME 32" Muddies n'stuff Report this post to a moderator | IP: Logged 12-15-2006 05:05 PM Advertisement Sponsored Links Ads by Google Supporting this site Also, check out these sponsored links: More Links: All times are GMT. The time now is 10:42 AM. Pages (2): [1] 2 » Last Thread Next Thread Show Printable Version | Email this Page | Subscribe to this Thread Forum Jump: Please select one: -------------------- Private Messages User Control Panel Who's Online Search Forums Forums Home -------------------- Toyota 4Runner Forum-- General Discussions-- 4th Gen T4Rs-- June 2009 T4ROTM-- 3rd gen T4Rs-- Classic T4Rs-- 5th gen T4Rs-- Gallery-- Audio & Electronics-- Off-Roading Stuff-- Comparisons & Reviews-- Accessories-- Special Accessory Offers-- Performance Zone - Tires, Wheels, Exhaust, Superchargers, and more!-- Pimp Zone-- Detailing-- Maintenance-- Problems & Warranty-- Classifieds - buy & sell anything related to the Toyota 4Runner (no commercial ads please)-- Polls-- Off Topic-- Dealers - Your Experience-- FJ Cruiser-- Lexus GX470-- All Other Toyota & Lexus Vehicles4Runner Clubs-- American T4R Clubs (click to view)---- Florida---- Georgia---- (The Rest of) The Deep South---- So Cal---- No Cal---- Pacific NW---- Southwest---- Texas & Oklahoma---- Carolinas---- Maryland / Virginia / WV / D.C.---- Northeast---- New England---- Great Lakes---- Ozarks---- Heartland---- Mountain---- Alaska & Hawaii-- Canadian T4R Clubs (click to view)---- Montreal / Quebec---- Toronto / Ottawa / Ontario---- Edmonton / Calgary / Alberta---- Vancouver / British Columbia---- Winnipeg / Manitoba-- European T4R Clubs (click to view)---- UK---- Germany---- Italy---- France---- Russia---- Scandinavia-- Asia & Oceania T4R Clubs (click to view)---- Japan---- Australia---- New Zealand---- Guam-- Africa & Middle East T4R Clubs (click to view)---- Nigeria---- South Africa---- Egypt-- Latin America T4R Clubs (click to view)---- Argentina---- Brazil---- Mexico-- T4R Meet Announcements & Info-- T4R Meet Pictorials & WriteupsSite relatedAnnouncements - Terms & Conditions of Use - Privacy StatementSoftware Related Questions & AnswersComments & SuggestionsLinks Rate This Thread: Select a rating... 5 .. Best 4 3 .. Average 2 1 .. Worst Forum Rules:You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is ON vB code is ON Smilies are ON [IMG] code is ON < Contact Us - Toyota - 4Runner . org Forum > Powered by: vBulletin Version 2.2.8 Copyright ©2000 - 2002, Jelsoft Enterprises Limited. ***This site is an unofficial Toyota site, and is not officially endorsed, supported, authorized by or affiliated with Toyota. All company, product, or service names references in this web site are used for identification purposes only and may be trademarks of their respective owners. The Toyota? name, marks, designs and logos, as well as Toyota model names, are registered trademarks of Toyota Motor Corporation***
Remote Start on 2008 Toyota 4Runner will not start truck
Is it a Toyota remote start, or an aftermarket remote start? If it is a Toyota remote start, make sure the hood and doors are all closed. press lock twice, then press lock a 3rd time and hold it for 3 or 4 seconds. It then should beep once, and a few seconds later start up. OR the lights will flass once, twice, or etc. Usually this means there's something wrong and the number of flashes is a diagnostic code of sorts. If this is the case, take it in to your dealer for further assistance. This part should be covered under the 3/36000 warranty.
If it is an aftermarket system, it will probably be a similar situation. It may be a misadjusted hood pinswitch, or even some blatent mistake the installer made installing it.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
